Posts: 111 |
i have no idea how this happenend, but it did. It is the bolt on the top right that is slightly recessed with minimal room on any side of it to work. the 7mm socket just spins. 1/4" does not fit either. I have no room to get any type of pliers on there to try that route. What can I do? need help so i can change my plugs/wires. thanks.
#2079
Posts: 351 |
It's not THAT recessed. I have a pair of vice grips that comes to a narrow point at the end that I can fit in there and turn that bolt (I just ran out to my car to try it). You may need to go out somewhere to buy some vice grips that will fit. You won't be able to get a good enough grip with pliers.
Black 2000 SVT Contour w/ Prairie Tan
MSDS Headers | Magnaflow | Mirko Splitter | Fidanza Short Throw Shifter | Kenwood KVT-815 LCD/DVD
Posts: 111 |
well i tried a small pair of vice grips i had, but i guess not enough of a point on them. i will have to go buy a different pair. thanks for checking.
#2079
Posts: 6,106 |
When you do finally get the IMRC cover off, leave it off. Need to let that IMRC box keep cool, as it'd suck to have it malfunction on you.
Mark
2000 Black CSVT
Posts: 351 |
But it's so pretty
Posts: 869 |
Originally posted by Big_B: But it's so pretty
Yeah and those CF ones are just so awesome
Posts: 2,426 |
Or you could do this:
Posts: 7,025 |
shouldnt it be an 8mm?
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 351 |
That looks nice... and reminds me of a question I meant to ask. If someone doesn't see this here, I will post somewhere else.
I put Magnecor competition wires on and I can't get them to fit back in that plastic holder/guide that is sitting to the left of the intake manifold because they are so much fatter than stock. Did you just jam them in there or did you have to modify the plastic piece?
Posts: 1,165 |
Originally posted by Big_B: That looks nice... and reminds me of a question I meant to ask. If someone doesn't see this here, I will post somewhere else.
You can take a dremmel and grind out the pieces to make them wide enough to fit the wires.
Also to the point of the topic. Also using a dremmel you could cut a slit in the top of the bolt head and then just use a flat head screwdriver.
I live in Detroit, I couldn't give a **** how good my car is in the "twisties."
"I could use a hundred people who don't know there is such a word as impossible."
~Henry Ford
