#103377 08/20/01 02:51 AM
justSVT Offline OP
If I took a larger ( 75MM housing ) and put the stock sensor in, would it cause problems or could it work? Do I need recalibration? Any hints would be helpful. Thanx in advance.
justSVT My Tour is a cross breed.
#103378 08/20/01 03:20 AM
Doesn't work, no power increase. Someone used the 65mm off the Mustang and still not power increase, it lost power it higher rev's
Chow
1998 SVT #2263 of 6535
chowsvt@msn.com
#103379 08/20/01 03:23 AM
F
F
He said MAF, not throttle body...
2000 Mercury Cougar V6 ATX. 16.0@87MPH, 155.0 FWHP
#103380 08/20/01 07:00 AM
What kind of increase can I expect from replacing my stock throttle body with a 65mm throttle body?
96 SE
SCA cold air intake
Cat-back exhaust
Flowtech muffler
Short shifter
#103381 08/21/01 12:32 AM
justSVT Offline OP
Some people who have tried it say it worrks great. Others try to prove it is not a worthwhile mod with a lot of technical arguments. There are some for sale out there that are cheaper than the majority of other mods. I say try it. I believe it would be most beneficial with an open intake and exhaust, but who am I? :p
#103382 08/21/01 06:54 AM
You'd get bad drivability problems since the MAF electronics are calibrated for a different housing...
2000 SVT #674 - Check it out!
#103383 08/21/01 12:10 PM
KJ Offline
You do need to recalibrate the MAF Sensor. I have the Pro-Flow MAF housing with the stock sensor bolted up. Drivability isn't bad by any means. If you are going to do I would suggest investing in the Optimizer and straping it do a dyno to get the correct calibration on it. laugh
Married the gal of my dreams 04.27.02 smile
2K SVT Black/Midnight Blue
#294 of 2150
DOB 10.29.99
kbucy@fbr.com
ktigerj on aim
A *few* Mods
Best Time 14.942 at 93.98mph
Car is now for sale - 14000
