Wow. You've got no scruples do you. You come on here and talk the same trash that you did on the GTP forums except that over here you say you let him win?
Your credibility is already shot by the way you run your mouth. Unfortunately for you, I (and most others) would have a hard time believing anything you say at this point.
BTW, I had a stock SVT when I got beat by a loaded GTP....except that I could still get him above 90 mph...barely. Yep, I think of the stock SVT as a bit slow, especially now. AT least I'm not a Liar. If I say I took something then I took it, if I get beat I tell the truth and take it like a man.
So that is all I'm going to say. If you look at my post above it only references things that I have actual knowledge of, or that anyone could suppose by listening to you. I have NOT said anything about your car, it's capabilities, or anything of the sort. The only thing I can make a true statement about you is the way YOU present YOURSELF in your writing.
WHY do I make this point you ask? To show you the right way to act by example....like SOMEONE should have taught you growing up. Because I don't know anything else about you or your ride and to make statements about that stuff would be talking out my arse.
I'd be really interested to see if you did put in a SHO motor, how it was done and any of the other adaptations you IMPLY you did to your car. That would be worthy if you supported it with photographs and carried on a normal conversation....basically if you aren't full of crap AND if you calm down and get mature enough to really participate on a forum.
So at this point I'm done feeding the Troll.
