Posts: 1,119 |
well I hooked up a sub and an amp (no don't move to audio haha) and I went to plug in my trunk light (it was out so not to kill the battery) and zap. No more interior lights are radio doesn't work. I know its a fuse. The only thing I changed on the sub was the ground. Its off now, but which fuse does the interior lights. This seems like a common problem, but no one has pictures!
1998 SE Duratec V6 ATX
Ebay intake with K&N Filter
Trubendz Exhaust
Custom Hood
Posts: 5,345 |
Originally posted by ZeroHour: . No more interior lights are radio doesn't work. I know its a fuse.
Have you changed your ATF yet? (on an unrelated post)
Radio is No. 32 and Interior/Courtesy is No. 34. In addition, there is a Relay No. R12. These are in the passenger compartment fuse box next to your left knee when seated on the driver's seat. There is a round knob. Push and the panel will drop down.
1996 V6 ATX 96K miles
Posts: 1,119 |
Well I found it. Anyone else in future reference:
Under the dash, driver's side is your fuse box (duh, but if you're new its a start)
find some uncomfortable way to lay there.
Facing upwards, to your right is a white-ish plastic box with wires. There is a small level, it opens the box.
Fuse #32 is interior lights, head unit(radio) and clock! its a 7.5 amber colored fuse. You should have on in your fuse box under the hood, along with a fuse puller!
Easy to find search action sentences: No interior lights interior light fuse Head unit not working Head Unit Fuse Clock not working Clock Fuse
Hopefully that helps someone else in the future cause I couldn't find much searching!
Trubendz Exhaust
Custom Hood
Posts: 1,119 |
no changing subjects, but not lol. The stereo is current work in progress. Its taking alot longer then it should have because I over-do everything and make a plywood mount to 1) hold the bass tube in place 2) safely mount the amp and 3) make it pretty. lol
Good addition to the post.
Trubendz Exhaust
Custom Hood
Posts: 5,345 |
Originally posted by ZeroHour: no changing subjects, but not lol. The stereo is current work in progress.
LOL. Priorities, priorities. LOL. Good night!
Posts: 403 |
I just had the same problem and this info helped, but, for my '96 Zetec it was fuse #34.
96 Sport 2.0L - 190,XXX miles
