#1365156 08/19/05 05:00 PM
Has anyone ever had trans fluid spray out the front seal, on to the clutch and spill onto the ground? Right after You just put sycro's and a torsen in.
My question is will i have to replace the clutch, its a spec II
IN 3rd gear at 3500 if i stand on it the clutch slips. But it doesnt do it in first
#1365157 08/19/05 05:10 PM
The clutch is probably slipping because it is oil soaked. Vey likely it can be cleaned with brake clean. You need to clean up the bell housing and pressure plate anyway.
As much labor as there is to get to the clutch, if in doubt, replace it. Clean it up and then try and make a determination. If there is even a shodow of doubt, replace it unless you don't mind going back in if it still slips.
I have suceeded in cleaning oil soaked clutches, but there were much easier to get to.
#1365158 08/19/05 07:09 PM
Hmm, did you replace the input shaft seal/slave cylinder when you had it apart, and if so what did you use - a ACTUAL Ford slave or a knock-off?
#1365159 08/19/05 08:16 PM
I agree. Sounds like the slave-T/O 0-ring/seal is leaking.
#1365160 08/20/05 01:41 AM
Man that sucks , hope I don't have any issues when I do mine .
Check me out for awsome powder coating deals www.powdercoatingworld.com People shouldn't slam each other when posting, If you cant say something good to say then just hit the back arrow.
#1365161 08/23/05 02:46 AM
The throwout bearing came with the spec stage 2 kit. So hopefully i only need a trans seal
#1365162 08/23/05 11:45 PM
You need a FORD T/O bearing. Aftermarket ones are just knock offs.
1998 CSVT E0 3L son's car - http://www.cardomain.com/id/svturbo 1998 CSVT E1 (Future 3L) daughters car Get in, sit down ,shut up, hold on
#1365163 08/24/05 02:25 AM
Wow, the worst thing that could happen for a kevlar clutch. I'd kiss it goodbye, I doubt it can be saved. I would bet my left nut that it will only glaze over now
2005 Ford F150 SuperCab FX4 1964 Chevrolet Impala SS 1998 CSVT: 354HP/328TQ @ 10 psi, now gone
