Posts: 12 |
I am about to install my 1st system and my friend said I would need a capacitator because my stock alternator is probably weak. Is this true?
I am running 700 Watts RMS... Will I have problems with lights dimming? will there be a huge drain on my battery? or will I need to buy a high output alt?
I do not really want to buy either one... but I do not have my system installed yet so I do not even know the problems I may have. How powerful is a stock contour alt? I heard it was 130 amp alternator... is that correct? Will that be able to handle me putting out 700 watts without any problems in my cars electrical system? Will I need to upgrade wires?
lol, so many questions. I am just confused. Will I have any of these problems? Any help is appreciated.
I feel Guilty, Oh so guilty
Posts: 4,789 |
Get your alternator tested at your local autozone. If its putting out significantly less output than it is rated for (130A) then replace it, potentially with somehting larger. That being said, 700w shouldn't even come close to taxing the stock electrical system.
-Mitch Hedberg
Posts: 12 |
thanks. Do you think I would even need a cap? That is what my friend recommended. Also, how much does it cost to have the alt tested?
Posts: 1,572 |
Having the alternator tested should be free .
Check me out for awsome powder coating deals
www.powdercoatingworld.com
People shouldn't slam each other when posting, If you cant say something good to say then just hit the back arrow.
Captain Impound Boy
Captain Impound Boy
Posts: 8,281 |
Caps are highly overrated!!!!! Get a yellow top way before you get a cap, They install the say way and a yellow top is only slightly more expensive.
But as dave said you shouldn't need either, Upgrade the Big 3 and you should be all set
Posts: 4,789 |
And I would recommend an Oddysey battery over any Optima. Might be a few more dollars, but well worth the investment.
-Mitch Hedberg
Posts: 566 |
Originally posted by dnewma04: And I would recommend an Oddysey battery over any Optima. Might be a few more dollars, but well worth the investment.
Why?
My yellow top has been perfectly fine, and I have put it through hours of engine off listening sessions since 2001 without a single problem. It also starts my car easily in the dead of winter too.
Bob Johann
SoundQ SVT
1998 T-Red SVT Contour #3088
2001 IASCA Pro Street 1-600 Champion
2002 SLAP Pro Street 1-600 Champion
2002 MECA SQL Master Class Champion
2003 IASCA StreetX 1-600 Champion
2005 SLAP Expert Street Champion
Captain Impound Boy
Captain Impound Boy
Posts: 8,281 |
Dave lives in a fantasy world where no name products out preform everything else...
I have a Red top now and its flat out amazing.. a yellow top will soon be added
Posts: 4,141 |
Originally posted by Kinda SteedaSan: Upgrade the Big 3 and you should be all set
waht are the big 3???
pardon my lack of knowledge here.
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
Posts: 1,859 |
Anybody ever upgraded the power cable from the battery to the alternator/starter, i.e. using a larger gauge wire and slightly larger mega fuse. If so any significant results? I may do this soon.
'99 Silver svt
For sale
19" Axis Neo wheels
3.0 parts, pre-98 trunk,
Check classifieds
bp.powell@comcast.net
