Posts: 52 |
on a rare day the car runs good i have the zetec dohc 4cl. contour. sometimes the car when i first turn her on let her warm up the car stalls.finaly after a while of keeping the pedal down a bit she warms up and barely idles. ive checked and replaced spark plugs and wire set oil to royal purple cust air intake fuel filter ive cleaned the iac ive added gallons of injector cleaner and isoheet to remove water. ive hosed down the egr and surronding vacuum lines with electrical cleaners. im not the best at typing so ignore the bad grammar. also when im on the freeway and i have the ac on the car runs better than when i dont have the ac on. when i dont have the ac on and im going around 60 to 80 the car suddenly acts like the fuel gets cutoff i start droping speed and i have to put the metal to the petal to the other metal to keep going. i can not at the moment change the pcv valve i cant figure out how to take the cat off i have a haynes manual but there some bolts that i cannot see that i need to remove to take that off. ive asked alot of people for help some have been cool and most have not to say the least. any help would be apreciated i live in dallas tx and would pay someone near me to help me or buy them beers. one more thing when im stoped at a light with the ac on i hear a sqeaking noise i think my belt tensioner is going out could that be the culprit of the loss of power it recently starting squeaking and the hessition on freeway and street sometimes came after the sqeaking started. if your not going to help me then dont leave any hatefull or deregatory statements.
Posts: 5,345 |
1996 V6 ATX 96K miles
Posts: 52 |
yeah ive already changed the fuel filter and i dont put gas in mom and pop stations anymore. my car will ruff idle or hesitate no matter if the tank is full halfway or almost empty so i doubt its the fuel pump. i do have cel codes and last time i checked lol the codes were about the oxygen sensors ive already switched both out bosch ones and nothing. with all the maintenance and improvements ive done ive gone from 18 mpg since i first got her to almost 28 mpgs that a heck of alot of gas money i save. i am going to buy a new iac for it but that female dog is hard to get to. last time it took me almost 3 hours to get it off and put it back on. yeah i know search on how to take it off i did and the articles ive found say take this off take this off and thats how i did it but i still cant get to it. i am buying extensions and those things that make your rachet bend at angles to get around all those small pipes and fuel rail. i have cleaned the entire intake system brand new air temp sensor ive hosed the maf and the pipes all down with all kinds of electrical or air intake cleaner.
Posts: 5,345 |
Originally posted by bigworm: . i do have cel codes and last time i checked lol the codes were about the oxygen sensors ive already switched both out bosch ones and nothing.
I take it you have changed the air filter. Next time the CEL shows up, scan it and post the code(s). Actually, scan it now (free at Autozone) just in case there are intermittent codes and see if you have some codes to post.
Edit. Dallas, Texas. We have quite a few CEGers in Texas.
Posts: 1,119 |
could be a very crappy air filter. Your IAC may just need to be replaced and cleaning won't help if the unit is dieing. Make sure you fuel filter is on the right way (  almost did that myself, but caught it before I lowered the tour back down). This maybe a far stretch but could these symtems being a fuel pump? I would get the CELs read at autozone. even if the light isn't on.
1998 SE Duratec V6 ATX
Ebay intake with K&N Filter
Trubendz Exhaust
Custom Hood
Posts: 52 |
lets agree for a moment that im stupid and i did put the gas filter on backwards what would happen ? before i changed the fuel filter it would hesitate just a little on freeway now it does it alot. im going to autohoe today to scan my car and buy the iac where its the cheapest for me around here.
Posts: 5,345 |
Originally posted by bigworm: ... put the gas filter on backwards what would happen ? before i changed the fuel filter it would hesitate just a little on freeway now it does it alot.
This could happen,
"car stalls.finaly after a while of keeping the pedal down a bit she warms up and barely idles."
And if the fuel filter was not changed in a long time and there was sediment in your tank, and if you did the filter change when your gas tank was very low in fuel, it could suck up the sediment and clog the fuel filter again.
It could happen.
Posts: 3,788 |
Glad that you decided to post your question! (Bigworm knows what I am talking about  ) Welcome to the CEG.
Posts: 52 |
ok the codes i got ladies and gents are i did not have a pen to write them down so i saved the numbers on my phone. the first code i got was p1131 i belive it was a p. the second code i got was p 1071 something about lean or rich fuel something like that last time i took it to autoho i got 3 error codes now i got 2 wu huu! i bought the iac thing and the dudes at autoho told me it would be in tomorow but i dont get off till 8 im going to pick it up and maybe install it that same night. its hard to get to whats the easiest way to take it off? the iac sensor majiger
