#103248 08/19/01 02:58 AM
Heat soak with the KKM in Texas is a @#$%$#@er. It should be called "heat suck" since it is sucking hot air from the engine.
I find heat suck very noticeable in city traffic. It annoys me enough that I engineered a very inexpensive heat shield tonight.
I bought 3 90-degree angle sheet metal roof flashings, for a grand total of 90 cents plus tax. They are 4"x4"x8". I screwed two of them together to make a U shape with a base of about 6" (slight overlap needed).
I then cut out a slot wide enough for the intake to fit in (about 4" wide). I then took the filter off the car and attached the third piece of metal to the "underneath the filter" position.
Now I have 3 sides of a cube, with a slot wide enough to allow the filter/intake tube to pass through. It holds the filter captive, or maybe the other way around. I then took the tin snips and trimmed the metal to fit under the hood and also trimmed the lower portion to clear some of the chassis. I wrapped some adhesive weather stripping around the razor-sharp upper edges, checked for fit, and hit the road.
Took it out for a drive. The impact was very obvious. I didn't notice any hesitation at all, despite high ambient and underhood temps.
Once back in the garage, I checked the temperatures of the shield and the filter element. The filter was at roughly outside air temperature. Good. The shield was too hot to touch!!! I think we have a winner.
laugh
Woohoo!!!
Sidewinder: 1999 SVT
Thud: 1998 SE V-6
Edgecrusher: 1998 Mercury Mountaineer, 5.0L
#103249 08/19/01 03:12 AM
Pics please? This sounds like a simplified version of my homemade CAI.
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
#103250 08/19/01 03:15 AM
Yeah, I'll try to do pics. But I literally *just* made it, and it is currently night - makes photography difficult. :p
Thud: 1998 SE V-6
#103251 08/19/01 05:46 AM
My current "heatshield" is made from the bottom of a very thick rubber waste basket.
Very cheap, very easy, & very effective...
My next one won't be though... laugh
2000 SVT #674 - Check it out!
#103252 08/20/01 12:15 AM
Let's see some pics DemonSVT and Sidewinder!
Ted Bush
2000 T-Red SVT
#1027/2150, Built 12/20/99
racertb@yahoo.com
#103253 08/20/01 04:13 AM
Sidewinder,
Once you cut it out nice, get a can of Duplicolor engine paint at Wall-Mart and paint it on both sides. You'll be amazed at the difference in temperature on the inside. of course, then it'll be a 5$ heat shield...
Marco Tatta
98.5 SE MTX, Duratec
EGR block, fog light
fix, custom shift boot, monsterflow intake, Ecotek valve
Quasi dual cardoctor exhaust.
Hacksaw short shift, Momo race "s" carbon knob, ghetto rear strut bar, 16 inch cougar wheels with 225/50/16 kumho 712s
