One of my tires got a bulge in the sidewall so I went to get it replaced yesterday, and when the car was on the lift we noticed that the inner tred on the other front tire was competely shot.
I got an alignment when I had put the tires on originally, which was only 19,000 miles ago, just a little over a year. However I am well aware of the fact that there is no camber adjustment for the 'tour w/out a camber kit, and the inner side of the tire being bare and the outer being fine would suggest a camber problem, correct?
So they had to order another tire, and I am going back in today to get it done. They suggested I get another alignment, but if you can't adjust camber, then that would be a waste of money wouldn't it?
My car looks slightly lower than other stock SVTs I have seen, so I have always had a suspicion that the suspension isn't stock. I guess I need to take off a wheel and check it out. If it is stock suspension, could a warn out suspension (90xxx miles) cause camber issues?
Sorry for the long post
