The parking brake on my '98 SVT will not engage or disengage properly anymore. It is rare that it actually engages, and if it does, it then does not want to disengage. This problem affects both rear brakes.
I've taken both tires off and poked around a bit. I believe that the problem lies in the U-shaped engagement arms (that the cables attach to). The engagement arms are very difficult to rotate in either direction (engage or disengage), even by hand. The cable has a hard time pulling the arms enough to engage them, and when the brake is disengaged, the springs don't seem to be able to force the engagement arms back to the fully released position (only partially).
Is there any way to lubricate or otherwise force the engagement arms to loosen up? Would it possibly help if I got replacement springs that are stronger? If so, anyone know the part numbers?
Incidentally, does anyone know of the part numbers for the black rubber boot that covers the end of the engagement cable? Mine are in pretty bad shape and could use replacing.
Thanks!
