F
F
Simple question ... needs a definitive answer from someone who knows first hand.
Best Regards,
Trevor Cole
New Edge Cougar Forums
Nope, powdered metal.
\'94 Cobra #4963/5009, black on black, not quite stock
Formerly owned a black '00 SVT, #1972
Join the SVTOA!
RIP - Ray "Old Fart Emeritus" McNairy
Powdered metal is compacted into the rough shape of a connecting rod and hot struck at 1024 degrees Celsius in a 600 ton press.Ford calls this process sinter-forged. All 2.5 duratecs have the same type of rods.
Mark
so i take it these are not good enough for high boost/high rpm applications? cuz if this turbo kit comes out, then there are gonna be several of us looking to run 14psi+ of boost, some may even want to go 21psi...
I think Brad is trying to get forged pistons as well....
Nik
1999 Mercury Cougar V6
KKM Intake,SVT TB, SVT Upper/Lower, 19lb injectors, Diablo Chip, MSDS Headers, Custom Exhaust, B&M Short Shifter, Progress Lowering Springs, 18" Axis TC's, OMP Strut Bar, AAM 24mm Rear Sway Bar, Koni Struts
15.09 @ 91.54(corrected, pre-SVT conversion, DiabloChip, and Injectors)
The 2.5L rods are the same as the 3L rods. They are good for at least 250-260 HP per a Duratec developent guy and the experience of one of the racers who raced 3 seasons at 260 HP with stock rods. May be good for more (World Tour has run over 8K miles at about 350 crank HP & counting). I am going to guess about 300HP may be OK (if you are not reving to 8000+RPMs) as sinter forged rods typically are good for 1.5X stock power if SCC is to be believed. With forced induction at least get an Accusump to protect the bearings which are intolerent of loss of oil & if you rebuild use the SHO trimetal bearings & forged rods to be sure.
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
Yeah, i am putting together a preliminary price list for all the parts necessary to make a beefy bottom end with a turbo...if the prices for key components keep coming down (i.e. Quaife LSD) then this will be better and better....and more possible for me... But you are right, do the bearings if they are gonna be in there anyways for the rods and pistons....
Nikolas
If you are going that far need 'billet' crank,forged pistons,Ti rods and a 'redline' @ 10,000....sign up here!
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
Stock crank is Billet and used in the duttweiler turbo Duratec. (among many stock parts) It made 450HP @6900rpm.
2000 SVT #674 - Check it out!
Stock crank is forged steel, and they used custom forged rods/pistons for the duttweiler buildup.
Join the SVTOA!
I dont plan on making more power than Duttweiler did with his engine....and if the crank was good enough for him (and from what i hear, that Focus is still running good, daily driver almost), then it is good enough for me... I am just waiting for news on rods and pistons...and then I will of course need to buy the Bulldog tranny... are you gonna be selling those Terry to folks like me out of state?
Nikolas
