Page 2 of 2 1 2
#102973 08/17/01 05:05 AM
JVT Offline
Good job Chris, just read the previous post.
Brad will get me the low CR 3.0,
and
you will get me the Turbo.
Now the bigger problem. Where's the money? frown
John
'98 SVT - modded
-15.01@91.8
'95 Suzuki GS500E
-faster than the above
---wanting a Speed Triple or Superhawk badly
#102974 08/18/01 01:20 AM
What will be the price? please let me know playazprez@hotmail.com
#102975 08/24/01 06:48 AM
V
V
Hey its been awhile since i've been on...seems like alot of interest in this turbo sytem.
Chris I wonder if you recall we spoke about the turbo system for a 95 contour GL. I am in the process of building the turbo system using a Garrett T3.
This is a warning to members that the turbo system is not plug n' play (supercharger) which seems to be what most members think.
A turbo system requires consistent tuning unless drastic changes are made to the EMS (engine management system) See TEC2, SDS, DTA, Motec..etc, if large boost is wanted (> 10psi). These changes including varying fuel pressures and spark timing. Some turbo kits even include re-mapped chips as an alternative to going to an EMS. Will you be including this ?
From your post http://www.contour.org/cgi-ubb/ultimatebb.cgi?ubb=get_topic&f=6&t=002826 you are offering a stage 3 kit which with my build up is a stage 1 - 2. I would highly recommend offering the blow off valve or a diverter valve AND a fuel management unit as your stage 1 [low boost ... 6psi] and the intercooler option [air-to-air maybe .. as this is a cheaper unit and a lot easier install .. depending on location and size of]. As from experience [btw, I own a turbo charged CRX .. garage project ... and my bro is putting together his VW turbo 2.0 at the moment] these are a necessity or else detonation will occur and crazy EGTs will occur and lean conditions occur.
Can you please explain to me your stage 4 and stage 5 ? I don't understand what you are doing here ? Are you offering a variety of exhaust manifolds for different flow characteristics?
Anyways, my point to this post is .... EDUCATE!!! everyone please surf the web about turbos, find a hi-po shop in your neighbourhood and talk to those who have installed turbos on cars. Ask them what they think about putting together a kit. It is not a weekend bolt on project but a passion in physics and engineering. Well, good luck on the kit and see you on the street !
#102976 08/24/01 02:11 PM
Administrator
Administrator
Originally posted by vball:
...Some turbo kits even include re-mapped chips as an alternative to going to an EMS. Will you be including this?
...and the intercooler option [air-to-air maybe .. as this is a cheaper unit and a lot easier install .. depending on location and size of]...
vball,
Depending on the need and boost levels, there will be something to manage the fuel/spark. It will probably be a chip.
The intercooler will be water/air because you will be hard pressed to find a way to plumb an air/air up front.
Stage 4&5 are just examples. There is a good chance that those items will just be options. The kit will be made to use stock exhaust manifold, uncut, and with the cats. Headers in the same shape as the manifolds will also work (i.e. MSDS).
One thing I can tell you, this turbo setup is not like most setups you might be familiar with. The turbo, piping, and intercooler is different.
As far as this being a "plug and play" application, I have a good feeling the tuning will be fairly simple. They have other kits for other vehicles that don't even require tuning to achieve optimal performance.
If anybody has reliability and longevity concerns, they have vehicles with their turbo kit on them that have gone over 100,000 miles with no problems.
Believe me, I want to give as much info as I can. However, the manufacturer is not equipped to handle 200 calls a day from people wanting to get a status on the Contour/Cougar turbo kit. smile
Thanks for your patience,
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
#102977 08/24/01 06:48 PM
Originally posted by Chris Hightower:
vball,
What about boost for my POS returnless fuel system?
I don't see why other people can't get forced induction to work with returnless systems when the new Miatas have the same shiznit and STILL can be turbocharged/supercharged.
I remember reading up on an install on a 2001(?) Miata and they added some sort of restrictor in the return line on the pump (it's all done in the tank), to boost fuel pressure. Jackson Supercharger were the guys doing it. Surely something similar could be done on the reutrnless Contours!
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
#102978 08/24/01 07:18 PM
Administrator
Administrator
Originally posted by Aussie SVT:
What about boost for my POS returnless fuel system? ...
There are a few ways to get a returnless system to put out more fuel.
1. Bigger injectors
2. Bigger fuel pump
3. Additional fuel injector(s)-(7th injector with piggyback controller, Paxton)
4. Trick the PCM into thinking it needs to put out more fuel (mess with the MAF, IAT, or O2 sensors)
These mods might also be used in combination. That "restrictor" trick you are referring to only works on return systems. Nothing to restrict on returnless.
The manufacturer for this turbo kit has found a way to work with the returnless fuel system on other cars. They feel they can get it to work on the Contour as well.
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
#102979 08/25/01 05:52 AM
W
W
Who is the manufacturer? Why are there 50 posts on here about a turbo kit and not one has said who is developing it? Rough numbers might be nice, a price +-500 or even +-1000 would mean something but means nothing without some knowledge of the product for comparison.
warmonger...interested...
1. Bigger injectors
2. Bigger fuel pump
The manufacturer for this turbo kit has found a way to work [b]with
the returnless fuel system on other cars. They feel they can get it to work on the Contour as well.[/b]
You can call me anything you like as long as it's nice.(all lies accepted)
99 Silver Frost SVT. #226 of 2760
Engine: 3.0 power!
Unique Stuff: Sunroof control module (#1 of 9)
Car Audio: Loaded and loud!
Check them out at
http://home.earthlink.net/~twilson1726
Page 2 of 2 1 2
