#1359551 08/12/05 03:12 PM
Mkoine Offline OP
Does anyone know the size of the socket needed to remove the front axle (spindle) nut? Time to do the front wheel bearings.
Thanks,
Mkoine
#1359552 08/12/05 03:30 PM
Under the Duratec Maintenance FAQ for wheel bearings removal
"Using the 32mm Socket and the long breaker bar, remove the "locking spindle nut" (large nut that holds the hub to the axle itself. You will need a friend to help with this. "
Edit. The link.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=v6maint&Number=895425&page=0&view=collapsed&sb=5&o=7&fpart=1
#1359553 08/12/05 04:03 PM
Mkoine Offline OP
Thanks Tony.
Sure is hot in VA right now,
MKoine
#1359554 08/12/05 04:05 PM
