Posts: 1,287 |
just wondering if anyone got this far in the car, and what i should/need to change?
Posts: 6,910 |
the normal stuff and the stuff that has failed
timing belt if you have never done it otherwise just keep up with keeping it running
- 95 Mystique LS - Zetec/5spd
Posts: 21,653 |
Inspect your vtec control valve.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 5,345 |
130K miles.  Congratulations.
Assuming you did the 120K mile severe schedule maintenance of oil/filter, spark plugs, air filter, PCV valve, inspect (drive belts, hoses and coolant strength), I would suggest going back to 69K miles on the severe schedule in addition to shortened intervals for fuel filter (2 years).
1996 V6 ATX 96K miles
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by Tony2005: 130K miles. Congratulations.
I have over that.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 5,143 |
Originally posted by LocoSCZ: Originally posted by Tony2005: 130K miles. Congratulations.
I have over that.
yeah, and you have ripped apart your engine at least 100 times.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 21,653 |
Originally posted by MAYBE aliasfriend: Originally posted by LocoSCZ: Originally posted by Tony2005: 130K miles. Congratulations.
I have over that.
98.5 SVT
Posts: 23 |
Well, my '98 has 430,000km (about 267,000 miles), and she's been a treat. I've done a lot of highway and city driving.
The only 'major' item that I've had to replace is the VCT solenoid a year ago, and an alternator... (whoopie...)
There's always the stuff like )2 sensors, PCV valves and such, but I consider those to be maintenance...
Other than that, follow the maintenance schedule, change the timing belt (and water pump!) when necessary (anywhere from 60K km to 100K km).
'98 Mystique (Zetec - ATX)
430,000 km !!
Posts: 453 |
I should probably change my PCV valve.
I changed waterpump, timing belt, flushed coolant, new plugs, air filter, I didn't replace my serpentine, but I should, it's got lots of cracks. I just turned 124k.
-Peter
Posts: 1,505 |
my car has 122k almost 123k last time i had it serviced was at 35k but i been keeping up with the plugs being changed the oil and filter, air filter and fuel filter and transmission fluid. i havent changed the fluid in the raidator and i never replaced the plug wires either
1999 Ford Contour SE Zetec with 137k miles.
AIM Name: ContourAlf
Yahoo IM: Contour_Freak
