BnyBen Offline OP
I was reading on the Mods page that you can remove the stock resonator and replace it with exhaust pipe. I dont have the money for an exhaust system yet so I was wandering if this will help let a little more are flow out of the engine, and also make it sound a little better. Also, I wanted to know if it will effect my car passing the MA exhaust inspections. It is a little strict. Also, would any exhaust place do this or would they give me a hard time. Where should I go to have it done? Anyone who has maybe removed it or has a little info, it would be great. Thanks. confused
95 Contour SE owner
mods:
Kurts Kustoms Intake
Yokohama H4 tires
Kenwood KDCX-811
Three MTX 10" Thunder6000's
MTX 775W Thunder6500D
Schoche 1 Farad Cap
Neons, etc...
http://ben.marcionek.com
You should be fine removing it. It adds maybe 3-5 hp but I don't think there is a dyno onit anywhere. Mostly for my car it made the car smoother and I did not go into secondaries as often during city driving. My gas mileage also went up from 210/tank to 225/tank.
Just an exhaust pipe (str8 pipe) may be a cheap mod but it is very loud and sometimes not very clean. Perhaps a hi-flow muffler, backwards glaspack (just as loud but clean)or a bullet resonator would be better in the long run.
If this doesn't answer your question then trying searching for "resonator" and you will definitely find what you are looking for.
Josh
Aka Spectra SVT
02 Dark Highland Green F-150 XLT
Mods: Gunrack and cowboy boots
