Tonight, while driving, the car stalled many times, for no reason, under acceleration or not and I have fully disconnected the subwoofer (from the battery AND the radio).
Disconnecting the battery and reconnecting is a quick fix. As soon as I disconnect and reconnect, car works fine and starts up on its own but will stall again in less than 10 mins.
I've noticed that when the car stalls, I cannot even start it on its own or a "push start". The battery needs to be disconnected and reconnected.
What does IAC mean?
The fuel pump has already been replaced lately.
Another thing I've noticed, when it stalls, or right when its about to stall, the red light on my center console that has CONTOUR molded on the plastic comes on steady.
My battery's power wire needs to be replaced as it has melted the plastic at the power connector's end (prior to having these problems) but this shouldn't be the cause of the problem as the car still runs fine. Even when stalled, the car still has power, I just can't start it.
There are no lights that turn on or flash to give me an idea of whats wrong, not even the check engine light.
Anyhoo, thats all I have noticed for now.
I appreciate the reply. Thanks
Rob
