Posts: 2,708 |
50/50 Water & Alcohol mix for regular use. For racing and other stuff a different substance will be used in place of the water. The pump I am looking at isn't anything more then a big inline pump and if it burns up well, its only costing me $25 bucks and it has a warranty. -Mark
You can do something for Love... You can do something for Money... But there is nothing quite so satisfying as doing something out of Spite. GTExtreme1@aol.com
Posts: 2,915 |
hey mark, i was reading a magazine and noticed this ad for water injection.....you might want to call them
the place is called seine systems the number is 888-799-0721
im just lookin out for ya....who knows if this will be any help or not but oh well
www.shox.com Dealer Koni's 135 a piece Eibach's 190 a set KYB's 70 a piece H+R's 225 a set see profile for website, aol name, etc Business:WestEndMobil@yahoo.com Personal:Corey_pimp1@yahoo.com 1998.5 SCSVT ($16000 takes it) 2001 GSXR-1000 1988 Corsica (the beater)
Posts: 77 |
I know a pump that will work. Actually I am using it for my water spray on my WRX intercooler(waitting for the right nozzel for water injection) The pump is a shurflow diagram agriculture model, capable even pumping motor oil at 50 PSI! It cost me $60 (on sale) and weights 4lbs. With two mist nozzels, the pumb is only clicking every 5 seconds to supply the pressure.
Posts: 2,708 |
Well the pump I just picked up cost me $25 and has a warranty... Not to mention it weighs about a half of a pound vs. the 4 pounds of the one you are talking about. -Mark
Posts: 168 |
WorldTour,
Regardless of what pump you use in the end....
Major kudos to you for engineering a sweet setup. It's great to hear that you are taking on a task like this from a learned perspective.
All the best to you. Keep us posted.
-Kurt
-Kurt
"I'm a little sceptical of that internet thing. After all, what's it got besides information?" -DB, 1/97
Posts: 77 |
Originally posted by WorldTour: Well the pump I just picked up cost me $25 and has a warranty... Not to mention it weighs about a half of a pound vs. the 4 pounds of the one you are talking about. -Mark Yes, good luck Mark. How much pressure do you have with your pump?. Proper pressure is needed to mist the nozzel without over-stress the pump. Under boost, the pump has to overcome the manifold pressure and mist the nozzel. It was only a suggestion anyway! :rolleyes:
Posts: 2,708 |
About 60psi. I am still trying to figure out how I am going to moint it because of the sheer lack of space. -Mark
Posts: 434 |
Originally posted by bnoon: Perhaps a dash of rubbing alcohol in with the water? Some other additive? I have to wonder about automotive coolant as well... Yeah, coolant will give your exhaust a nice sweet maple syrup odor
Posts: 2,708 |
hahahah yeah I get bored with my motor so I inject coolant into it.. make the dealership think I have a blown head gasket or something so I can get it replaced.  -Mark
Posts: 5,805 |
Use a rehostat to set the pump voltage Vs speed/pressure,wont cook the motor then!
