#1356691 08/09/05 05:44 PM
Majisto Offline OP
When I went to change the pads on the Contour, I noticed that the passenger side pads were worn to the metal while the driver side had maybe 20% life left. Neither caliper seemed to be stuck, but I wonder what else could be wrong? Suspension seemed to be intact and tire pressure was equal.
2000 Contour SE
#1356692 08/11/05 06:29 PM
Majisto Offline OP
Bump...
2000 Contour SE
#1356693 08/12/05 05:02 AM
20% difference isn't all that much. It could be normal.
Make sure that you properly lube everything going back together.
Lube the caliper slide pins and make sure that they don't bind.
Lube every part of the pad backing plate that touches the caliper, especially any edge part that slides.
Use brake caliper grease.
#1356694 08/12/05 12:09 PM
get always with wings....
EGPLNT:MY 95' SE MTX SVT *200,000 MILE CLUB* 6/06/06 - 201,000 MILES
#1356695 08/12/05 12:56 PM
Z
Z
That could be gunk build up on the sliders. so one might have been moving slower or sticking longer because it didn't move as fast. Good thing you changed them if it was down to metal!
1998 SE Duratec V6 ATX Ebay intake with K&N Filter Trubendz Exhaust Custom Hood
#1356696 08/14/05 06:21 PM
Majisto Offline OP
I used the grease that Autozone gave me on the back of the new pads. I was shocked that there didn't seem to be any sort of wear indicator. Every once in a while the brakes could squeak lightly, but now even the new pads are squeaking when I brake on hills...
2000 Contour SE
#1356697 08/16/05 04:02 PM
U
U
BG makes a product called brake quiet that you pour on the face of the pad that helps, also try cleaning all brake components with brake cleaner, that should help some. Also have your rotors turned as well, they might be heat hardened.
99 ATX Contour 130k w/ a 21k tranny freshly installed Secret Project in the works
Originally posted by unknown:
Never argue with an idiot, ppl may not be able to tell the difference between you.
