Posts: 55 |
Shaking, smell, the-loss of power brakes.
On the way home from work this evening my CSVT started to shake when I got up to highway speed. So, I got off the highway and pulled onto a side street. I was checking the wheels/tires to see if I could tell what was making the car shake at high speeds.
That is when I noticed the smell of something burning. It smelled like burning clutch. However, the clutch is working fine, and was replaced about 14,000 miles (1.5 years) ago.
Anyway, I decided to take the back roads home. That is when I noticed a total loss of firmness in my brake pedal. I was still able to stop the car, but the loss of firmness in the brake pedal made the brakes feel unresponsive. It was frightening.
So I stopped again. The smell was still there and there was the sound of something sizzling as it dripped. There appeared to be no fluid of any kind on the ground. I could not see what was dripping. I only heard a sizzle about every 10 seconds. I checked all of my fluids and they all seemed to be fine.
Then, after driving very slow and carefully for about ten minutes, everything went back to normal. No more shaking at high speeds and the brakes worked fine. Also, I didn't notice the smell at all when I got home.
I am confused. Please help.
Recent problems I have had: 3rd gear synchro grinds, I changed the MTX fluid (with the honey) right when the 3rd synchro started to grind. The honey fluid helped but there is still a slight grind into 3rd. This was about 3 weeks ago. Also, my ABS computer fried out about a year ago.
Again, please help.
98 svt contour
90K
black
only owner
no accidents
bilsteins!!
Posts: 5,345 |
1996 V6 ATX 96K miles
Posts: 1,456 |
A quick test, does the car roll freely if you release the parking brake while in neutral? If not, you have drag in your brakes. It's possible there is air in the brake lines too. Sizzling drip could be just a/c water, and I hope that is what it is!
Posts: 55 |
Originally posted by FavoriteMystaque: A quick test, does the car roll freely if you release the parking brake while in neutral? If not, you have drag in your brakes. It's possible there is air in the brake lines too. Sizzling drip could be just a/c water, and I hope that is what it is!
The car does roll freely
98 svt contour
90K
black
only owner
no accidents
bilsteins!!
Posts: 5,345 |
Originally posted by bunnymann: Originally posted by FavoriteMystaque: A quick test, does the car roll freely if you release the parking brake while in neutral? If not, you have drag in your brakes. It's possible there is air in the brake lines too. Sizzling drip could be just a/c water, and I hope that is what it is!
Actually, you need to jack it up and turn the wheels.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=1017692&page=&view=&sb=5&o=&fpart=1&vc=1
Posts: 7,100 |
exactly... the weight of the car will, obviously, push through the minor drag you may be experiencing. (of course it will, othwerwise you'd not be driving at all.. and you'd not have a burning problem... you'd have a "I can't get the car to roll", problem...)
Jack the car up...
Ray
'99 CSVT - Silver #222/276
Posts: 55 |
Originally posted by Tony2005: Actually, you need to jack it up and turn the wheels.
Tony, Ray - I will jack it up and let you know of the results.
98 svt contour
90K
black
only owner
no accidents
bilsteins!!
Posts: 55 |
Originally posted by bunnymann: Originally posted by Tony2005: Actually, you need to jack it up and turn the wheels.
Jacked up the car - all 4 wheels turned fine.
98 svt contour
90K
black
only owner
no accidents
bilsteins!!
Posts: 1,456 |
See if there is air in the brake lines, bleed the brake system, that's what I would check next, since all wheels are free when cold. Check the action of the calipers, definite apply/release. Air bubbles in the lines can cause the brakes to apply by themselves, it happened to me.
