Posts: 1,367 |
Well I turn the key one click, and the battery chimes sound fine. Radio works fine. All that.
Turn it one more, to give power to windows and whatnot, and everything goes dim and sounds like the battery has very little power left.
If I go BACK a click, then it's fine again like stated befoer.
I tried to jump start my car, but all I get is a clicking repeated over and over again. Nothing else. Lights come up and windows work at full power again when in accessory mode, but the car won't start.
Is it a dead starter? Or is it bad cell in my battery (if it's even possible) that's causing this?
Thanks!
Sal Khan
00 SVT - Not pretty
00 Aprilia RSV Mille - Also Loved.
http://www.thelunchjournals.com
"I just want someone I can stand once her mouth is free of obstruction."
Posts: 157 |
can you tell what the batt voltage is? if it doesnt even click or try to turn over, its probably the battery.
~Crystian
2000 Se sport
2001 Lightning(Sorry!your mom cant come with us)
Posts: 5,345 |
Originally posted by SalKhan: Well I turn the key one click, and the battery chimes sound fine. Radio works fine. All that.
Thanks!
To test the battery, turn on your headlights for 60 seconds, then the voltage should read slightly more than 12.
As you tried to jump but did not succeed, it is probably not the battery.
It could be no gas or starter. If you have an owners manual, check if the emergency cut off switch is triggered (for the gas).
Edit. Fuel pump cut off switch in hole next to lever to unlatch the hood (near your left leg when sitted on the drivers seat). Press the button to reset.
1996 V6 ATX 96K miles
Posts: 1,456 |
My friend's Taurus wagon refused to jump, battery was shorted somehow. Try recharging the battery with a charger, if no go, time for a new battery. If it starts, check charging system, 14 volts range after start.
Posts: 1,367 |
Much to my demise it was not the battery. I dropped in a new one to no avail. So looks like I get to get a little dirty..... er.
Sal Khan
00 SVT - Not pretty
Posts: 285 |
Check your relays! You also want to check your battery cables. Make sure they aren't cracked or corroded. This leads to voltage loss due to extra resistance. Check the ground wire under the battery tray for corrosion around the bolt where it bolts to the frame.
Parting out 95-97 Contours/Mystiques. Contact me directly at ALFIGOLS@yahoo.com if you're looking for a particular part.
Posts: 1,367 |
Well I checked the cables, they looked good.
Relays looked fine too.
But I'm gonna just have the dealer look at it. I removed just the motor first to make it easier to get to everything else but for the life of me, I can't get the gearing assembly off. So when I went to put it back together, one of the little roller gears fell out, and I tried to look for it everywhere with no luck.
Goddamnit.
Sal Khan
00 SVT - Not pretty
Posts: 857 |
try tugging at the cables. I had a similar problem, the cables looked fine but when I tugged the ground the terminal broke off. I doubt it's the starter, it sounds like the problem is coming up before it's even engaged. Sounds like the car can't draw enough current from the battery. Check the fluid levels in the new battery too, make sure they're full.
Posts: 44 |
Does anyone know how one checks the relays? I mean, other than visually inspecting them to make sure they haven't exploded or something... Is there a resistance specification they should be at, or should one just check continuity at the relay, or what?
My car will not start, and I've gotten the battery recharged...mine will crank, though, so it's a little different situation, but no start. I have gas in the tank, and I've checked the coil and the wires and plugs are new, and the coil is firing, so I'm left with either a reclusive electrical issue or a fuel issue... I'm ruling out an air issue, because I checked the filter, and I've kept the throttle body and IAC and MAF clean, and the car started before I put it in the garage for a couple weeks...blah.
1997 Ford Contour Sport, 2.5L Duratec V6, MTX
Posts: 285 |
If you car cranks but doesn't start and the fuel pump is working, check the ignition relay under the dash. It's fairly common and often overlooked. One way to tell if it's the problem is to turn the car to the run (NOT start) postion and see if your power windows work (or blower in no power windows). If they don't then you have a bad ignition relay.
