csvt99 Offline OP
I'm getting my bilstein struts and BAT springs installed tomorrow. Are there any extra parts or special instructions specific to this set up that the mechanic might want to know? I couldn't find anything by searching, TIA
99 T-green svt K&N & heatshield Opt. y-pipe Borla Superchip DMD Magnecore wires Metal impeller water pump BAT / Bilstein kit 21mm BAT bar w/ boxed subframe 215/45/ZR17 Toyo Proxes FZ on Rage 5.0's jimmkreider@yahoo.com
They are stock replacement parts, so it should be pretty straightforward.
-Philip Maynard '95 Contour [71 STS | Track Whore] '97 Miata [71 ES | Boulevard Pimp] 2006 autocross results
csvt99 Offline OP
What about the bumpstops? still cut the fronts in half?
Huh?
-tropictour
2000 Contour SVT Tropic Green SHO Shop CAI Bassani 1999 Contour SE BAT Kit
The BAT springs are high enough I don't think you'll need to trim them.
csvt99 Offline OP
Ok, thanks for the help. I'll mention something about it to the mechanic i guess
csvt99 Offline OP
My car is finally done, I had the subframe reinforced, new front LCA's installed along with the BAT kit with bilstein struts. The front is a half inch higher than stock and the rear is a quarter inch higher than stock. I think I remember reading another post where the same thing happened with bilstein struts. I'm assuming it just needs time to settle. I went with the bilsteins in order to minimize the drop, so I won't be devistated if the drop isn't that great. Also, compared to other svts, my car seemed to sit lower so I think the suspension was probably saging to begin with. I'll take some measurements around the 25th and post the drop numbers then, after it settled a bit.
And no...i did not cut the front bump stops...but if i understand things correctly, they have nothing to do with ride height
You didn't need to cut them, obviously. Take measurements and post tire size and ride height. Check out my General thread on the ground clearance topic and compare numbers.
csvt99 Offline OP
The car is still at the shop (needs to be aligned tomorrow) but I will post measurements when I get it back. I recorded all the measurements before I took it in so I should be able to see how much it dropped
Have you been following all the alignment threads for info on what settings you might want? It'll be more noticeable now with a taut suspension.
