Posts: 1,336 |
In case you where wondering what it costs to bore/balance these blocks, I just got my block back from the shop 2 weeks ago:
- 99 Taurus Block (60K miles, $585 shipped. I bought this block around 2 years ago) - Clevite Rod & Main Bearings - Pauter Rods - Diamond Racing Pistons (9.0:1) - All Studs/Bolts for 01+ Windage Tray/Oil Pickup
Services rendered:
- Give the block a "bath" - Remove the transmission bearing/collar - Bore the cylinders to accept the pistons - Fit the pistons/rings/rods/bearings - Balance rotating assembly
Cost: $980.77
Posts: 5,882 |
Originally posted by fastcougar: Cost: $980.77
hope this isnt a stipud question but is that total cost involved? or just for the services you listed below?
im debating over getting the ADC prepped motor or one from a salvage yard....
Posts: 317 |
i'm not fastcougar... but i'm willing to say the 987$ is just for the services....
2000 Cougar V6 MTX
2001 3.0L Swap w/ PnP Heads - It ran, it boomed, it RUNS AGAIN
Nearly all suspension mods
Big ass stereo
...and more...
See Her Here
Posts: 352 |
Correct, Puck- Considering Trevor and I had our shortblocks assembled at the same shop. $980.77 only included the Clevite main & rod bearings- All other parts were supplied. That was mostly labor.
Dan G. and his Cougar
Forged internal (Diamond & Pauter) full 3L, "Monster" Kinger F/I cut & P&P, T3/4 60 trim .82A/R ADC turbo, SPEC Stage 3, Torsen, Greddy Profec-B SPEC II, Apex'i Timer, Lots of Gauges!
Used to have: 3.0L SVT hybrid
Posts: 1,336 |
Originally posted by DanG: Correct, Puck- Considering Trevor and I had our shortblocks assembled at the same shop. $980.77 only included the Clevite main & rod bearings- All other parts were supplied. That was mostly labor.
I can supply a cost breakdown when I get home ... the work order/receipt is on my workbench in the garage.
Posts: 352 |
Got it right here:
Clevite 77 Tri-metal Rod Bearings $35.19 Clevite 77 Tri-metal Main Bearings $53.17 Fit/Align Piston Pins $40.00 Bore .020" over $120.00 Clean Block $45.00 Labor - Remove Pilot Bearing, machine camshaft, clean timing cover, assemble shortblock $280.00 Race Balance of engine & add weight $380.00 Sales Tax $4.41 Shipping, Clevite Bearings $23.00 Total: $980.77
Posts: 5,810 |
So expensive when I look at it. I did all my own work on my hybrid and the machine shop work I did have done including new valve seats and machining came to less than $400. There was no block work since the block was low miles so that would add to it but I'd think having it 'tanked' for a good cleaning and have it "mic'd" for cylinder taper and wear wouldn't be much more than another $100 if no additional work was needed. You can easily install the rods and mains yourself. The mains don't need changed ANYWAY! Unless you are repairing a damage crank. Change the rod bearings of course but those are easy.
See My Mods
Posts: 1,336 |
Forged internals = more reciprocating mass = needs to be balanced = majority of cost over what you have stated = not really that expensive considering the work being done.
Posts: 21,197 |
Originally posted by DanG: Shipping, Clevite Bearings $23.00
You know you can get them through Napa right?
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 1,336 |
Originally posted by todras: Originally posted by DanG: Shipping, Clevite Bearings $23.00
We handed the engine shop our blocks, parts and asked if they could get the bearings and they said yes ... we did not supply the bearings.
