Posts: 206 |
What is the difference between an SVT engine with a build date after Aug. 1, 1997 vs. before? Was this the E0 to E1 - sounds like too early a date? Eric
Posts: 250 |
2/9/98 was the beginning of the E1(195HP)production. I don't know when the 99's(200HP)began production. Mark
Posts: 33 |
From what I found this date was about the time the changeover from EEC IV to EEC V (PCM'S) and the dual throttles were changed from vacuum operated (my car) to electricaly operated. This might only apply to the UK.
Posts: 3,248 |
E0 and E1 engines the same 195HP, only suspension/tire/wheel/brake etc changes. 99s got 200 HP, sometime mid 1998 I think.
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 1,770 |
There might be something to this question... the first 50 SVT's were partially hand-built, and I wonder if any of that pertained to the engine.
Posts: 1,682 |
Originally posted by hector959: From what I found this date was about the time the changeover from EEC IV to EEC V (PCM'S) and the dual throttles were changed from vacuum operated (my car) to electricaly operated. This might only apply to the UK.  dual throttles?
Posts: 33 |
ok ok secondry throttles, IRMC or any other colourful name you have for this system in the US
Administrator
Administrator
Posts: 702 |
Originally posted by hector959: From what I found this date was about the time the changeover from EEC IV to EEC V (PCM'S) and the dual throttles were changed from vacuum operated (my car) to electricaly operated. This might only apply to the UK.  Um, this is a load of misinformation. The only Contour's with EEC-IV PCM's are 1995's. 1996+ have EEC-V. The IMRC valves went from vacuum to electrical at that time, also. Has NOTHING to do with throttles. -Lance
Lance Kinley CEG Webmaster 95SE, "Official CEG Beater" Quaife, SVT parts, ST200 wheels, SS Y-pipe I perceive you to be a stand-up, rational individual...
Posts: 3,419 |
Isn't that about when Ford went to "depowered" air bags? I know it has nothing to do with the engine, but I thought I'd throw a couple of pennies into this thread.
Posts: 7,329 |
Gen II airbags came in with OBD-II - 1996
