#13920 05/03/02 05:35 PM
BIGS Offline OP
I know many people have the KKM intake and along with that they have that "moosing" noise. Now i had this prob and then someone suggested doing the TH FIX. Now my car always ran fine before that but sounded like ****(from the moosing).so i got the copper pipe cap and drilled the 3/16 hole in it and put it in and it sounded better for about 2-3 weeks. then recently i went to start my car and noticed the idle was not normal. it was idleling very low, almost bogging out. and it got worse until finally i started my car and it wouldnt start. So i had to hold the gas all the way down start the car and hold it like that for like 1/2 min until it ran. my mechanic happend to be with me at the time(fixing another ****ing prob with the car) and told me you cannot place an obstruciton like that in your intake. It causes the engine not to perform as it should( he went to greater detail). so i took it out and of course it ran fine with no prob. So in the end the th fix will decrease the noise, but your sacrificing engine performace/durability.the engine is not getting the proper ventilation.
98 SVT
MODS:
Something or another
#13921 05/03/02 09:01 PM
Thats funny cause I and many other ppl have been running it for years now with now without any problems.
Did you reset your ECU after you added the copper pipe?
I actually didn't even do it to kill a moose noise (didn't have one) I did it to kill the tremendous Throttle Hang I was experiencing.
Also I have tried revertting back several times and each time I end up putting it back in due to so much throttle hang smile
Go Figure
Justin
1998 Black SVT
jcboeckl@unity.ncsu.edu
#13922 05/03/02 09:27 PM
Administrator
Administrator
Uhhh.. That's crap. The copper cap is just for the IAC. It is supposed to restrict the air going through the IAC passage. However, the hole should be big enough to let the engine idle properly. A complete passage blockage wouldn't let the engine idle properly. Did you read the part about drilling the hole wider so it idles correctly?
No need to call something a "lie" just because you didn't get it to work the first time.
You just disrespected Ray McNairy. Bad mojo! :p
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
#13923 05/03/02 09:38 PM
Ray Offline
R.I.P. Ray...
frown
Check out my car!! (Profile Registry)
Have a Nextel two-way? check out my registry for my number!
Ray Haralson
Jacksonville, FL
s_r_haralson@sar.med.navy.mil
srh@texas.net
YIM: midnghtflm
AIM: midnghtflm
NEWEST MOD: a BEAUTIFUL girlfriend for my one and only passenger.
#13924 05/03/02 09:40 PM
Seriously bad mojo eek
Kharma is very real and she is one mean b!tch.
#13925 05/03/02 09:44 PM
BIGS Offline OP
it not bull****, i did read on to the other part about making the hole bigger, and i did do that.I probably shouldnt have said its a lie, rather i should have said its one possible solution, but it was not for my car. just didnt work, and i realy dont think restricting the airflow is good regardless.just have to put the stock one back and sacrifice the 2 or 3 horsepower it pumps out. laugh
98 SVT
MODS:
#13926 05/03/02 09:51 PM
Ray Offline
heh heh.. Yeah.. "What I WISH I'd said, was...."
smile
Ray
Ray Haralson
Jacksonville, FL
srh@texas.net
YIM: midnghtflm
AIM: midnghtflm
#13927 05/03/02 09:55 PM
BIGS Offline OP
if you wanna get technical it was i lie, it didnt work for me, so id call that a lie, but since everyone gets really jummpy here i said what i did. im sure its a good idea and works for many, but i just stated my own experience. no offense.
98 SVT
MODS:
#13928 05/03/02 10:16 PM
9
9
First, I have the fix in my car for a year now... What kind of weather were you having when you first installed the fix? If it has gotten substantially hotter or colder, you need to redrill the hole in another cap for this temperature.
~~~~1999 Contour SE Sport~~~~
-KKM True Rev
-All Cat's fixed.
-SHO Shop Off-Road Y-pipe
-Many other Mod's done...
#13929 05/03/02 10:18 PM
i use a 7/32nds hole all year round smile
works like a champ!
Todd Christ SVT Contour Registry
MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator
'98 E0 SVT Contour #1037 of 6535
