Page 3 of 3 1 2 3
#1351222 08/03/05 07:15 PM
Okay, it appears that water is seeping in between the hood and the fender on the passenger side. My suggestion is to tape some weather stripping under the edge of the hood (passenger side) so that, that area (entire edge) would not have any small gaps when you close the hood.
#1351223 08/03/05 07:20 PM
looking at this picture:
1) WHy does this fender has such a long sidewall. mine is narrower and shorted
2)where the drain is(below guy's hand) i drilled a bigger hole.
3) i have coved pcm below power steering container and above
so water is on top of everything
1998 Contour V6 Duratec 2.5L
#1351224 08/03/05 07:28 PM
As I mentioned earlier, yours could be an aftermarket part. You just have to try different ways until it works.
Not sure what drain you are talking about. I will check mine tonight.
#1351225 08/03/05 08:56 PM
What in the world was Ford's rationale for putting the PCM under the hood in the first place? I guess putting it in the passenger-side kick panel like they do for all their other cars was too proven, and made too much sense.
'99 Contour Sport V6 MTX
#1351226 08/03/05 09:02 PM
Unfortunately, that might also be a problem. Some of us have experienced water coming into that area too.
#1351227 08/03/05 10:16 PM
"2)where the drain is(below guy's hand) i drilled a bigger hole."
I was just wondering. Did you check if the drain is clogged? Might be good to pour some water in the drain to see if it will really drain. Drilling a bigger hole won't help if the drain is clogged.
#1351228 08/04/05 03:00 PM
hi
drain is ok. i poured water and its all going down.
i have protected pcm to the best of my ability now
1) took pcm out and dryed it
2) coved all connectors with dielectric grease
3) sprayed wires with plastic spray and plastic bag
4) got a long sheet of flexible plastic and taped it from firewall along a fender.
5) inside colw area, covered two bolts with some silicone(they were rusty but i dont think were leaking)
now its just needs to rain...:)
Page 3 of 3 1 2 3
