#1350897 08/02/05 05:35 PM
my svt is in the shop now because it boggs down and dies on the freeway..
i took it to a shop and they say everything is fine wiht the fuel system...
the problem is its cutting out signal to the injectors...
so its either a computer or a wiring harness...
does a wire harness just go bad??
has anyone heard of this...
#1350898 08/02/05 05:37 PM
sure it's not a spark problem? coil pack?
2004 Evolution VIII cams-exhaust-tune 315whp 12.7@109
#1350899 08/02/05 05:49 PM
spark plugs are practicly new... the mechancis say its the computer or wire harness.
#1350900 08/02/05 05:57 PM
Unfortunately it does just go bad. But let's hope it is not the problem for you.
Here is a TSB for some of us.
http://www.contour.org/FAQ/recall/99M03/
Yours could just be one harness.
#1350901 08/03/05 03:56 AM
That recall applies only to 95-97 if you check it out.
I don't think it is the harness, but if it is, plan on taking a trip to the junkyard.
A fuel injector harness for a V6 is $700 new from Ford.
