i cant find a how to or post on this can any one help. sorry if i mised it.
blk 1998 svt contour custom paint by taylors house of color sho y pipe and hi flow converter fms 9m wires open element filter and sloted cross drilled roters
I'm afraid I don't know what a vertical a-arm is. We have two horizontal a-arms that serve to locate the front wheels, is that what you mean? Search for LCA (lower control arm) if that is the case: beware, there are two kinds of arms, your car could have either.
?He could be referring to the same thing you are, just that the two difference LCA's have either a vertical set of mounting holes, or a horizontal set...
I dunno..
Ray
'99 CSVT - Silver #222/276
Originally posted by Kremitthefrog:I like to wear dresses and use binoculars to watch grandmas across the street.
Ah, yeah, that makes sense. If you are looking for how to swap the ones with the vertical bolts, I have a write-up somewhere I'll post for you. Basically, I cut the bolts off where they wouldn't come, and put the new ones in from the bottom.
yes i have the lower control arms with the vertical bolts. i want to replace them with out droping the sub frame. could some one link me to a how to the one i found used to have pics but now its not there anymore.
