Posts: 12 |
While in the store buying cookies someone in a big truck felt the urge to try to back over my car. well long story short i need to know if a contour hood and grille will line up with a 99 mystique's headlights. and if not then will contour lights fit into my mystique fenders. any help you might be able to render is very appriciated.
Posts: 425 |
nope, not compatible. just like ibm and mac.
1998 Ford Contour Se 2.5 litre Silver frost
Posts: 1,303 |
correct me if im wrong, but if you have a mystique cant you put the bumper/hood/lights/fenders from a contour on (i mean all together). or vice versa? i know just swaping one wont work, but could you just do all of them?
Goonz12: <---tries on mommy's cloths
Posts: 425 |
you'll have to swap the fenders also because the lights are different, i do belvieve so.
Posts: 650 |
fenders are the same on post 98 contours and mystiques.
97 Zetec MTX Sport
Mk1 Mondeo Morettes & Clear corners
Full SVT kit w/ Molded Mirko Splitter, Carbon Fibre Hood
Ground Control coilovers w/ Koni adjustables, BAT anti roll bar
Pics of my rides in my profile!
Rally drivers do it sideways......
Posts: 1,047 |
Originally posted by Plastique_synthetiX: fenders are the same on post 98 contours and mystiques.
Yeah,the pre98 Mystique's have the rectangular wraparound lights. In 98,they went to the same shape as the contour. You should be able to swap a Contour hood,grille,lights and bumper onto your post98 Mystique no problem. If you only swap the lights or something,they won't line up with the grille etc,everything will be out of whack.
Your best bet is just go on ebay,you can get lights,grilles and bodyparts cheap. Or if you can go to a wreckers and get a whole contour front end cheaper,then do it.
Best of luck. I hope you smacked the idiot in his teeth for doing that to your car.
'95 CGL ZMTX - DOB: 8/94 - Daily Driver - 271k & counting - Ractive muffler,MSD ignition coil,KEM 8mm wires,Pre98 SE 7 spoke rims,KVR CF brake pads,Post98 sail panels,Sony Xplod HU,Pioneer 3-way 6x9's
'89 Mazda B2200 - Under Construction
Posts: 191 |
Just out of curiosity would a post 98 tour, hood/lights/fenders/bumper fit on a pre 98 tour?
98.5 SE 2.5L MTX - TruBendz Borla, Green Filter, SVT F/R Bumpers, E1's
95 SE 2.5 MTX - Full SVT Body w/Mirko, GC + Konis, Omp, KKM, SVT pipes, E1's, Paint
Mods/Pics
Posts: 736 |
I think that was covered a long while ago and IIRC they wont
99 ATX Contour 130k w/ a 21k tranny freshly installed
Secret Project in the works
Originally posted by unknown: Never argue with an idiot, ppl may not be able to tell the difference between you.
