Posts: 267 |
So Ive searched around on here and Im just trying to gain some assurance before I drop more $ trying to solve my excessive EGR flow CEL.
Ive read pretty much every pertaining post about this CEL and Im pretty sure my dpfe has kicked the bucket.
Ive tested my valve with the vac test and it seems to be working propely. What makes me think that the problem is DPFE is the fact that the CEL seems to turn on while the car is idling.(seems like a sign from what Ive read on here). I used to have some idle issues but that was caused by a lean side (CEL). Yet that was cured with a easy MAF cleaning. Then I was back to only a excessive EGR flow.
Also the CEL tends to turn off at times and turn right back on. Now if it was the valve/egr itself, then it would always be on since it's a mechanical piece. Where as a sensor can seemingly have it's good days and bad days like a sick patient.
The car has 85K+ on it so it seems like it should be done anyways. Just trying to assure myself this possibly is the right thing being that I hear it's a pain to reach.
Thanks
Posts: 157 |
Have you tried cleaning the EGR ports? i had the same problem the CEL pointed to the EGR but after cleaning i got another code pointing the DPFE.
there is a how/to that u can search for the cleaning
~Crystian
2000 Se sport
2001 Lightning(Sorry!your mom cant come with us)
Posts: 267 |
Originally posted by Crystian: Have you tried cleaning the EGR ports? i had the same problem the CEL pointed to the EGR but after cleaning i got another code pointing the DPFE.
I am going to do that along with the DPFE replacement. Its just that it seems that the clogged ports lead to the eventual death of the DPFE.
So if it's the ports clogged, chanches are that my dpfe is messed up as well.
Im leaning towards it being the DPFE, and if it isnt it prolly would fail soon anyway so why not replace it.
Posts: 267 |
WOW, did it and Ive really become acustomed to the cut back power from the cel.
Why didnt I do this a while ago?!? (prolly cause that screw closest to the firewall is a [censored])
Cleaned out the intakes nicely too.. Feels good
Posts: 4,141 |
i threw a ton of money at my car trying to get rid of that same code...it was my DPFE that was the problem.....
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
Posts: 21,197 |
They go pretty quickly. It takes just a hint of moisture. I've heard cases of some going every 20k. It has been revised by Ford. I think the new ones are plastic.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 6,910 |
Originally posted by todras: They go pretty quickly. It takes just a hint of moisture. I've heard cases of some going every 20k. It has been revised by Ford. I think the new ones are plastic.
yes this is the case as I recall
you are correct, if you manually applied vacumm to the egr and it died at idle then it is the DPFE sensor and it will fix the problem, I know as it happened to my car also
- 95 Mystique LS - Zetec/5spd
Posts: 7,117 |
Hope you did this too! Enjoy!
Posts: 661 |
I've had 3 CELs in my SVT's 6 years...every time it has been a DPFE (once it was two of them).
They seem to go every 25,000 km.
$120 little suckers.
Kerry
99 SVT Contour Silver Frost, #365/2760, DMD
98 Audi A4 2.8 Quattro Tiptronic, 30V -- SOLD!
91 Isuzu Impulse XS Kammback, Handling By Lotus
Victoria, BC, Canada
Posts: 9,602 |
Originally posted by kerrychin: $120 little suckers.
OUCH!
Only $50 south of Hockey land.
I'm on my second with a spare (plastic one from the 3L) sitting in the garage.
2000 SVT #674
13.47 @ 102 - All Motor!
