#1345533 07/27/05 12:18 PM
rjclark Offline OP
Horn stopped working, Cruise control stopped working, and the air bag light flashes once every 4 or 5 seconds. Does this sound like the clock spring is faulty? Is it a big fix?
#1345534 07/27/05 01:54 PM
#1345535 07/27/05 02:03 PM
rjclark Offline OP
It' a Mondeo so the codes are a little different. It is code #1. One flash cycle.
Airbag fault codes for Mk2 airbag SRS system
Number denotes number of flashes
1 - One flash cycle: Driver air bag module squib resistance out of range
2 - Two flash cycle: Passenger air bag module squib resistance out of range
3 - Three flash cycle: Short to battery plus or ground in section of air bag squib circuit common to both driver and passenger air bag modules
4 - Four flash cycle: Safety belt buckle pretensioner(s) failure. Short to battery plus or ground in safety belt buckle pretensioner circuit(s)
5 - Five flash cycle: Driver side air bag module or circuits failure
6 - Six flash cycle: Passenger side air bag module or circuits failure
7 Seven flash cycle: Driver side impact sensor or circuits failure
8 Eight flash cycle: Passenger side impact sensor or circuits failure
#1345536 07/27/05 03:48 PM
