I have been having trouble with my electric cooling fans coming on, thought it was the relay, turns out a mechanic told me that there was a recall on the wiring harness for that car specifically relating to the electric cooling fans. I wanted it to run it past you guys to see if anyone can validate this or if he is blowing smoke. Any direction would be helpful. New coolant temp sensor, new engine temp sensor, fuse is good, and fan motor works with +/- connection. Thank you.
