#1342726 07/24/05 03:10 PM
Just got back from a trip to the beach in NC, and with about an hour left in the drive my airbag light came on and has been blinking continuously ever since then. Just curious if anyone has ever experienced this before, and what steps the took to fix the problem
thanks alot
1998 Svt Contour
82000 Miles
#1342727 07/24/05 04:44 PM
#1342728 07/28/05 01:05 AM
well its throwing this code:
51=Air Bag Diagnostic Monitor Internal Thermal FuseFuse Blown Due to Intermittent Short to Ground
let me know if anyone has any experience or any clue on how to go about fixing it.
thanks guys
#1342729 07/28/05 02:08 AM
Seems to me I'd want to change the fuse for the airbag monitor, and see if it blows again. The whole "due to intermittent short" thing is more of a catch-all comment, not necessarily a positive diagnosis.
I would change the fuse, if possible, and see if it blows again. if not, you are good to go. if so (likely), you will have to track down what is shorted and causing the extra current flow.. (blows the fuse)
Ray
#1342730 07/28/05 02:20 AM
Welcome back Ray.
#1342731 07/28/05 08:34 PM
does anyone know where the air bag monitor switch is located? It's not the one in the fuse box underneath the dash.
thanks
#1342732 07/28/05 08:43 PM
#1342733 07/28/05 11:09 PM
mine has been flashing 51 since i got my contour.the dealer i bought the car from sent it to a ford dealer to fix.ford held it for 2 days and didnt do nothing.i was told that fuse is not replaceable and the whole diagnostic module 250 to 300 dollars needs to be replaced.ford would not replace the damn thing until they found the swinging short. i said give me my damn car back .ill wear my seatbelt! i also saw posts here on how to eliminate the whole airbag system light ,bags etc.
95 contour se 52000k electric red
#1342734 07/28/05 11:22 PM
I see. Check out this post and you will understand why they will not replace the diagnostic monitor until the short is corrected. If the short is not corrected, you will just keep "blowing" the monitor and they will have to replace it under warranty each time. I take it that per Ray's suggestion, you put in a fuse and it blew right away.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=560913&Forum=trouble&Words=air%20bag%20code%2051&Match=Entire%20Phrase&Searchpage=0&Limit=25&Old=6months&Main=560328&Search=true#Post560913
If you are looking for the Air bag diagnostic monitor, it is located in the area under the radio and behind the storage "box". You need to disconnect BOTH battery terminals and wait 15 minutes or so before even thinking about touching anything relating to the airbag. They have an additional backup power.
#1342735 07/29/05 01:57 AM
well thanks for all your help guys, i temp. just pulled the bulb so I dont have the annoying blinking, and i guess ill start shopping around for estimates for getting it fixed
thanks
