I am currently looking for a tranny to replace my breaking one.
(third gear grind issue, now 2nd gear)
I have a 98.5 Ford Contour V6 MTX-75
I have found a 96 Mystique V6 5spd transmission for a really good deal..
Are the two interchangeable ? or are they the same?
Thanks for any help
Martin
98 Contour V6 MTX CTA Exhaust/CTA Intake/MSDS Y-pipe/Bat Handling Kit/Predator Alarm/Spec1 Clutch Kit/SVT Flywheel/G Assurances Fix your car yourself "It's not a UFO." Todras
I do not think it will work without extensive modification. Pre-98's are rod shift compared to cable shift which is what comes on post-98's.
-tropictour
2000 Contour SVT Tropic Green SHO Shop CAI Bassani 1999 Contour SE BAT Kit
since they are both from a V6 you are all set there but the whole rod vs cable shifter would be the issue
I understand that you cannot convert the transmission from rod shift to cable shift, and that converting the car to accept the other shifting mechanism is not easy since it was not built with the intention of being able to be converted.
Basically, it is not practical to make the switch. The one person that posted that he had converted an early car from rod linkage to cable linkage said that he would never attempt it again.
Thanks for the replies.
With your and Terrys help I am now looking for a 98 Transmission.
cheers
how much where you getting that 96 trans for...just wondering cause i have a 96 that needs a trans.
http://www.geocities.com/nos_xteam/My_car_page.html Wanted= 96 MTX75 for a 2.5 for a good price!
The Gentlemans name on the boards is: Imo000
If you go to the Eastern Canada Forum you can see our thread.. but unfortunately he is located in Cambridge Ontario.. a large distance from Wisconsin .. so if you want to work out a price with shipping you can contact him via PM.
Cheers
Martin
