Posts: 41 |
Does anyone have a "how-to" (w/pics if possible) for a motor mount install.  Those are the mounts i have and cant figure them out. Please help. Thanks for your time.
2000 CSVT Black
Magna Flow Exhaust
KKM True Rev Intake
17" Enkei DM5 Yokohama ES 100 215/45/17ZR
Carbon fiber front and back
All in all... a fat car
Posts: 4,141 |
useless......
they do nothing.
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
Posts: 41 |
Which mounts are the ones i need to replace then.
2000 CSVT Black
Magna Flow Exhaust
KKM True Rev Intake
Posts: 4,141 |
what you have ther is an insert for the front roll resistor located behind the radiator on the subframe. The inserts do absolutly nothing, i had them in my car before doing my solid poly rear and noticed absolutly no diference. i replaced them with a solid poly front after doing my solid poly rear. if you don't mind a little extra noise and vibration in the cabin, solid poly is the only way to go on the roll resistors. ask the 40+ people i've sold them to
Totaled 02/12/06
Posts: 9,602 |
Originally posted by poleNEEDS A TRANS120: useless......
they do nothing.
Not true. They ES inserts stop the typical driveline lash during shifting. That's a nice upgrade for many folks that think excessive NVH is bad.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 768 |
Originally posted by DemonSVT: folks that think excessive NVH is bad.
I am one of these but the inserts are still useless
Posts: 2,469 |
Originally posted by DemonSVT: Originally posted by poleNEEDS A TRANS120: useless......
they do nothing.
demon is def. right on this one. I put them in years ago and noticed a big difference. It didnt eliminate wheel hop like i was hoping but it did help. I realy hated that "bucking" when you were in low gear and you would get on/off the gas, and thats were the inserts realy shined.
Posts: 4,141 |
they do nothing.
if they do actually do anything, the effects are minimal, after installing them months ago prior to any other roll resistor changes, i noticed no diference from stock....i am not a believer
Totaled 02/12/06
Posts: 768 |
Originally posted by alex_96GL: Originally posted by DemonSVT: folks that think excessive NVH is bad.
I thought about it a little more and I am ready to revise this one. back in the day when I first installed the insert I thought that the difference was noticeable. I felt like shifting became more precise for example... so it's not useless altogether.
it is absolutely useless as far as wheel hop is concerned (which was not as much of a problem before I switched to g-force sport tires)
so I guess I agree w/ Demon AND Pole
Posts: 41 |
Does anybody have a how-to?
2000 CSVT Black
Magna Flow Exhaust
KKM True Rev Intake
