{You stated that you COULD get the car to start by holding the gas down. on a fuel injected car this is not needed, but that is a way to test the operation of the IAC.}
Ray, that is correct. The car will immediately start flooding when trying to start. Holding the throttle full open allows enough air intake to finally overcome the flooding.
I also found by pulling the fuel pump fuse it will start right up. As soon as it starts, I replace the fues and the idle settles.
Here is where I am now.
Alt was toast. Burnt and dead. Wires tested ok but heat damage on a few small ones. I have rewired to repair that and have the new Alt in place.
The car started right up, without pulling the fuse. Voltage read 13.8v Engine light was on but went out for a few seconds, then returned.
Idle slowly dropped to about 500 and alt. stopped charging(low rpm). Holding Idle up, voltage came back to 13.3v(kind of low)
I pulled the IAC to clean and inspect. It looks to be worn out. Has no fixed positioning, like the spring is detached. I ordered a replacement to install today.
This car is driving me
