Posts: 212 |
After reading several post the idea that many gave was to go get a tranny rebuilt at a smaller shop that depends on a reputation. So I was gogin to do that, but i go to College fargotm my home so i need something with a warrenty that was flexible so I went to AAMCO, and they charged me 1600 for a complete rebuild: Torque Converter, 1 motor mount, intertal crap, etc, car is running better than ever, i enjoy riding it again, I did not get the tranny cooler, I read alot of people are saying to get onw with a fan, perhaps a hayden, I am just wondering What Model exaclty and approx cost, and should I have them drain the fluid and put Syntetic oil since i only put about 50 miles on the tranny, I must say those guys did one hell of a job, do not be so quick to disregaurd them as an option
Posts: 51 |
You need a parallel flow efficient cooler, not a tube and fin style cooler which wont shed the heat as well. Tube and fins are one continuous tube, parallel flows use stacked plates or tubes. Also these ATX have no decent filtration of particles, they use an internal metal screen filter sort of like window screen. Every small particle of grit that comes off the clutch packs simply circulates around with the oil grinding away like sandpaper and that is why people talk about changing fluid every 10 thousand miles, but really since it is not filtered well, they are just delaying the inevitable result. You put the filter in the line, AAMCO sells inline filters. Ford sells one, and you can get one at CarQuest for $22. The filter and cooler need to go in the return line and this is the line coming off the bottom hookup on the radiator.
I used a ford focus cooler ( 23 inch by 5 by 3/4 )and fit it in front of the stock power steering pump cooler, An easy install, no trying to force it in the spaces where it was not designed to fit. Or you can try and find one long and narrow. I got mine on ebay. Use the space you have, some people try and force coolers between radiator and condenser where there is almost no space.
Posts: 21,197 |
Where did you come from? Need more knowledgable ppl like you around.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 6,106 |
Originally posted by Plain ole' todras: Where did you come from? Need more knowledgable ppl like you around.
I was wondering the same thing!
Reg date: 7/10/05
Mark
2000 Black CSVT
Posts: 51 |
I bought a 98 contour for my daughter and decided to share a little here.
Posts: 6,106 |
Originally posted by sdowney717: I bought a 98 contour for my daughter and decided to share a little here.
Welcome aboard! Hopefully you stick around!
Mark
2000 Black CSVT
Posts: 980 |
Originally posted by Y2KSVT: Originally posted by sdowney717: I bought a 98 contour for my daughter and decided to share a little here.
Mark
2000 Mystique LS
Duratec 2.5L MTX
Posts: 3,944 |
Originally posted by Tisby: Originally posted by Y2KSVT: Originally posted by sdowney717: I bought a 98 contour for my daughter and decided to share a little here.
Mark
Yeah, downey posted the other day about his focus cooler install. He is the only one that has gotten back with me about any information on the install. Many people have talked about doing it, in the past, but only a few have actually done it. I hope downey sticks around for a long time.
As for the cooler info he shared, not trying to dis downey by any means, but this information can be found all over this forum. The info downey shared is about as common `round here as anyone else telling a new member that he should get an LSD and updated shift tower for his MTX-75.
Phillip Jackson
`98 Mystique LS
262K+ and counting...
ATX rebuilt @ 151K
Posts: 21,197 |
Guess I need to read more ATX posts.
-'96 SE MTX 3L
Posts: 1,176 |
I've installed the stacked cooler fins as well as a spin on atx external oil filter that BigJim mentioned awhile back......Uses standard oil filter such as for the engine. Easy to replace and I do it at every other oil engine change for the atx filter.....
The filter in the atx a standard poly substrate material. The problem is that the filter is not replaceable unless you take the atx apart. As miles build up and if the filter becomes clogged or restricts flow, there is a bypass feature that allows the oil to still circulate but alas it is no longer filtered....Ford gave an award to this company for designing this type of filter......I would have thought the best route would be to design a filter that is replaceable........oh well I guess the throw-away concept is at hand.
Bob
