Hey every one i have a 300 watt invertor in my car i was thinking , Perhaps i could Ground the the wire to the body, then take the hot wire and run it to the direct to battery and i could have a switch drilled into my dash so i could controll the power from there instead of reaching under my seat to do it. And on the hot wire run that switch of course aswell as a fuse on the wire even though the invererer already has one. I was wondering If i did the connect is it a good method and will my device connected to my invertor still stay on if i turn the car on and off, unlike the cigarette adapter switch. Any adivce would be great, if there a better way to do it so the inverter will constalnly remain on unless I turn if off plesae let me know
ALso, I have a Pioneer TV(dash), 2 head rest Tv's, (Perhaps this inverter), I am getting a Tranny Cooler with the fan, and i have a remote start. Any electrical system Mods i should make to accomdate all of this. Is a Gel Battery (Optima) needed. I DO NOT HAVE ANY amps. ANY HELP Is welcomed thanks in advance.
