#101724 07/22/01 09:43 AM
O
OJ Offline OP
O
I finally got my Y-pipe after 2 months of waiting. But all I got was 4 pieces, 3 u-bolts, and a gasket. No instructions, No packing list, No anything of help on putting this thing together or anything like that. Has anyone installed this thing themselves? If any of you have could please email me a how-to? I have the resources to get it done but I just don't have the know how yet. I really hate how sho shop operates but oh well that another story. Thanks for any help.
ojdurham@hotmail.com
SSG "OJ" Durham
Mannheim, Germany
2002 BMW 330I
Steel gray metallic
Sports Package
Premium Package
Heated seats
Bi-xenon lights
trunk mounted CD changer
Euro Clears
Custom floormats
18" BBS Challenge rims
20% tint all around
My webpage
99 SVT T-Red #691...SOLD
99 SE Silver atx (wife)
#101725 07/22/01 07:19 PM
O
OJ Offline OP
O
Just pushing my question back to the top until I get an answer.
SSG "OJ" Durham
Mannheim, Germany
2002 BMW 330I
Steel gray metallic
Sports Package
Premium Package
Heated seats
Bi-xenon lights
Euro Clears
Custom floormats
20% tint all around
My webpage
#101726 07/22/01 11:11 PM
W
W
Well OJ, I'm going to type this directly off the instructions I recieved with mine.
Step 1- Using wd-40 or equivalent spray all bolts attaching factory y-pipe. Let sit for approx. 30 minutes. Undo bolts at each header and back at the catback flange. Remove the factory y-pipe.
Step 2- Install front long and short elbow pipes. Loosely attach them to the exhaust manifolds. Slide pipes into catalytic converter or bypass pipe. Thread in 02sensor and plug it in.
Step 3- Slide flex pipe at the back of catalytic converter or bypass pipe. Attach flange part of the flex pipe to the catback, do not forget the gasket.
Step 4- Place muffler clamps on the front and rear of the converter or bypass pipe. Make sure that the assembly is straight and does not hang down, tighten down clamps and front and rear bolts at the exhaust manifolds.
Step 5- Start car and verify that there are no exhaust leaks. If you find some leaks, make sure that the flange is straight and evenly tightened. Orange RTV high temp silicone can also be used to sealthe leaks.
Step 6- If you are replacing your convertor make sure to fill out replacement form for proper warranty registration.
Step 7- Happy Hunting! laugh
2000 SVT
silver/blue #1699 of 2150
14.793@94.88
Sho-Shop off road y-pipe for sale($75)
#101727 08/01/01 08:37 PM
O
OJ Offline OP
O
can I get anyone to second this. Not that your wrong or that I don't believe you but I don't have sh!t to go off of.
SSG "OJ" Durham
Mannheim, Germany
2002 BMW 330I
Steel gray metallic
Sports Package
Premium Package
Heated seats
Bi-xenon lights
Euro Clears
Custom floormats
20% tint all around
My webpage
#101728 08/01/01 08:47 PM
that looks exactly like the instuctions that i got with my y-pipe.
definitely use wd-40..it will make you life easier. it took me about a hour to do it. the hardest part (aside from working under the car) is getting the pipes to line up while working on your back. not that hard just takes a steady hand.
-- i forgot one thing..
Try not to destroy the nuts/bolts from the pipe that is closest to the cat (the 180 degree bend pipe) I had to resuse those bolts because they did not send me any. long bolts go to the front pipe and short bolts go to the cat-back to flex pipe.
joshua_drew@hotmail.com
AIM "nerdsalot2"
1998.5 Black Contour SVT
1998 ZJ Limited 4.0L AWD
#101729 08/01/01 08:56 PM
O
OJ Offline OP
O
did anyone get bolts with their Y-pipe? If not what kind did you use? Because I am in germany they will be a little harder to get but I will try to find some somewhere.
SSG "OJ" Durham
Mannheim, Germany
2002 BMW 330I
Steel gray metallic
Sports Package
Premium Package
Heated seats
Bi-xenon lights
Euro Clears
Custom floormats
20% tint all around
My webpage
#101730 08/01/01 09:08 PM
hmmm..
i recieved short pipe
other pipe
2 flanges
hi-flow cat
flex pipe
2 smaller clamps
1 larger clamp
2 short bolts/nuts for cat-back
2 long bolts/nuts for front pipe
1 gasket
1 instruction sheet
I could not tell you the size.
AIM "nerdsalot2"
#101731 08/01/01 09:27 PM
O
OJ Offline OP
O
see, F%$k damn sho shop!!!!!!!! They didn't give me **** but the damn y-pipe. Probably because I called them like every other day until the finally shipped my stuff. Looks like they will get another call, thats if they even answer the damn phone this time.
SSG "OJ" Durham
Mannheim, Germany
2002 BMW 330I
Steel gray metallic
Sports Package
Premium Package
Heated seats
Bi-xenon lights
Euro Clears
Custom floormats
20% tint all around
My webpage
