Posts: 126 |
well this car is starting to frustrate me. I have had a p0401 code since i got the car that i cant seem to get rid of. And its also comming up with a few others right now. p0153 and the code reader says pending so im not sure what that means. p0171 and p0174 as well. I tried cleaning the maf to no avail and i dont know where to start for trying to track down a vaccuum leak on this thing. Should i just pull off the upper intake and go through everything? I was also curious how many lines go to the DPFE, i took a look since i know thats one thing that may be causing the p0401 and there is only the 1 plug and one line going to the tube thats closest to the block, is there supposed to be a line going to the tube closest to the fender?
1997 Mercury Mystique
-Tinted, Debadged, and no more door ding guards
-Dual Exhaust With Magnaflow Mufflers
-Gutted Precats
-SVT rear sway bar w/ES bushings
Posts: 126 |
Well i pulled off the intake and im trying to find a new set of gaskets for it. Heres some pics i snapped of the vaccum lines to see if it all looks right.
-Gutted Precats
Posts: 5,345 |
There is one line to the EGR and two lines to the DPFE.
You might want to check out this site for P0153, P0171 and P0174. I had P0171 and P0174 once and it was a broken vacuum line. Yours could all be related to the EGR.
Maybe a gasket is leaking (?). Others will chime in with their suggestions.
http://www.v8sho.com/SHO/TSB0197HO2SServiceTips.htm
1996 V6 ATX 96K miles
Posts: 2,017 |
2 hoses.
1996 2.5LT V6 Contour ATX My Tour+help/info pics
E0 rims, Gutted Pre-Cats,CTA Custom Exhaust & Intake, Diablo Chip.
Posts: 5,345 |
Chongo, I was trying to find this picture. I had saved it on my hard drive. BalticBlue93 6-12-05. This is an excellent picture to show most of the left side engine components.
Posts: 1,456 |
The way you have the connections looks unusual, but might just be so you keep the hoses in view? EGR needs its green hose, 90 degree bend in it.
Posts: 126 |
Where does the other hose on the DPFE go to? I cant seem to see a place for it to go, or see the hose that would have falled off for that matter. Maybe we snagged it when we did the alternator or something.
-Gutted Precats
Posts: 126 |
Bump. i want to get this fixed before a camping trip next weekend.
-Gutted Precats
