Posts: 532 |
Guys, I've been thinking - with all this talk about manually pinning the secondaries open - why not just wire in a switch to activate the IMRC whenever you want? This is of course assuming that it is working at all! That way - if you want the secondaries "pinned" open - you just have to flip a switch, and forget waiting for the computer to open them up (somewhat sluggishly) at ~3500 RPM. Should not be hard to do on the newer cars (I believe the older ones used vacuum). I think I am going to pursue the matter on my own this weekend if I have time if I can find a way to "inconspicously" wire in a switch (I like my warranty).
If this has been tried before, just ignore my ignorance! I however would like my secondaries to open a bit quicker, and don't want a chip...
Dave
99 T-Red&Tan SVT/high flow res/K&N/painted grills & calipers/V-one/tinted windows/baby seat #2228
93 Escort GT Automatic (need I say more ->> it's the wife's car)
"I like long walks, especially when they are taken by people who annoy me"
Posts: 124 |
Originally posted by svtman1999: Guys, I've been thinking - with all this talk about manually pinning the secondaries open - why not just wire in a switch to activate the IMRC whenever you want? This is of course assuming that it is working at all! That way - if you want the secondaries "pinned" open - you just have to flip a switch, and forget waiting for the computer to open them up (somewhat sluggishly) at ~3500 RPM. Should not be hard to do on the newer cars (I believe the older ones used vacuum). I think I am going to pursue the matter on my own this weekend if I have time if I can find a way to "inconspicously" wire in a switch (I like my warranty).
If this has been tried before, just ignore my ignorance! I however would like my secondaries to open a bit quicker, and don't want a chip... Hey...if you figure out how to do this please post a HOW TO on here!!!!
Big gulps huh? Welp, see ya later
Posts: 2,148 |
If this has been tried before, just ignore my ignorance! I however would like my secondaries to open a bit quicker, and don't want a chip... Sounds like a good way to confuse the OBD II to me. Would be cool to wire nitrous and secondaries to the same switch maybe.
Former owner of 1999 SVT Contour #555
Posts: 265 |
Dave - I can go you one better on this idea.  Feel free to try it out and report back here if you do this. It's on my list of things to do at some point, but there are a few things ahead of it in line.  MSD sells an rpm switch that uses a variable module for activation between 1000-3000rpms. What I was thinking of doing is using that switch to fire the imrc activation circuit at about 2800-2900rpms. Cost for the msd stuff is only about $70 from summit. I know, I know, I am the man.  Dan Beggs 99 Cougar V6, loud
Posts: 413 |
Or, like someone mentioned before, you could use a computer like an Apex VFC to control the secondaries.
They can be used to change VTEC ativation, so they should be able to change IMRC activation also....and add or subtract fuel accordingly.
Patrick
mailto:paw@ite.com Still plays with cars 1999 SVT #2003/2760 Born on 04/22/99
Posts: 972 |
i just wanna pin the secindary open and forget about it.. although a switch sounds cool, dave, gimme a call or IM me and we could brainstorm
95 SE Champagne Mettalic True Dual exhaust with X pipe and Redline mufflers KKM Tru Rev intake H&R Springs/KYB struts Apex-i S-AFC 65mm Throttle Body 17" Ace Spades 4 Pt Racing Harness Window Tint all around New Engine @ 117k kilometers G-Tech: 15.6 @ 91.5 MPH
"you officially kick ass" quote from awed CEG'er after i chopped my hood and threw on scoops
RIP 98 SVT silverfrost *nov 4 2001*
