Welcome to CEG!
Disconnecting the vacuum from the FPR should raise fuel pressure. Best to check fuel pressure operation before buying parts though.
There are many possibilities here:
- Static timing
- High fuel pressure / bad FPR
- Bad MAF or connections
- Leaking injectors
- O2 going bad
- PCV system plugged
- EGR leakage
- A combination
Good Luck
