Originally posted by daenku32:
I'm still dreaming of doing 15.5s or 90mph, wichever might come first.
Just got back from the track. Second drag event in my life, temp in upper 80s and a high dew point. Not to mention I did not have any chewing gum to make me look cool.
btw, I got BFG g-Force KDW tires and i was wondering if a little 'burn out' would help at all. I'd like them to last at least a year.
And what's up with the speedometer? I could swear it was pointing at 95 or so, and I only clocked 87. Can't just be the non stock tires?
I don't think a burnout will help much. You see, when you get in the water box, water gets all in the tread grooves of the tire...when you stage, any excess water left in the tread will flow down to the bottom while you are waiting on the tree. Could actually cause you to spin off the line.
I think that what you should do is skip the water box...just drive around it. Before you stage, dump the clutch and get the tires to spin over a couple of times just to clean off the tread. Then stage and go.
