Hi guys, first time poster. I need some help with my 1998 Contour. Here's the symptoms and what I've done so far to fix it.
1. Car idles funny. The RPM's dip and the car shakes.
2. Shifting gears is very jerky.
3. Car stalls at random times. At random times I'm usually decelerating while on Neutral.
4. Check Engine Light On.
Okay, so I took it to a mechanic, and the check engine light was complaining about the O2 sensor and a broken pipe (Cant remember what its called, had to do with air intake. I'll post again when I get home and have the reciept.). Anyways, now the check engine light is gone, the car dosen't dip and shake at idle and shifting is smooth again... BUT the car still stalls at random times, especially when i'm decelerating at neutral. I'm guessing this is actually two separate problems, but I am at a loss (and so are the mechanics) as to what the problem is.
Any help would be appreciated.
Thanks,
Riz.
