Posts: 127 |
i lost 7-8 mph off of my Trap speed and gained +2 seconds on the ET after i gutted the cat. I have 0 in the cat, no resonator, but i have a muffler in the rear. what would give me the most backpressure without replacing the cat? putting a cherry bomb or muffler in the middle where the resonator was?
Posts: 127 |
a guy at midas said i should take the cat off, and weld a pipe inside of it, and put it back on... ??
Posts: 3,066 |
Then you get the gasses to go straight out, whereas a empty chamber might disrupt airflow a bit.
STD's are like Pokemon... Gotta catch em' all!
Posts: 127 |
thats what he said, hes like " the gasses are just bouncing all around in the insides before it flows out, and its not making good flow which is making you slower" so... i gotta get a pipe, but what do i do for the outside edges? the pipe wont fit the whole thing....
Posts: 3,598 |
Correct, a hollow chamber will lower exhaust flow velocity, which can possibly lower your power.
\'94 Cobra #4963/5009, black on black, not quite stock Formerly owned a black '00 SVT, #1972 Join the SVTOA! RIP - Ray "Old Fart Emeritus" McNairy
Posts: 212 |
back pressure adds exhaust velocity but putting somthing strait inside there will bring back the velocity and not add anyback pressure. I had all three cats gutted on my 95 and there was a tremendous loss of power but when I got my off road y-pipe It produced so much. .8 in my et drops same road g-tech.
98 silver frost SVT custom built intake, offroad y-pipe,mystery mod,remote optimizer,short shifter,zex nitrous, lots of stereo, 17 konigs
with paradas.(bent) TOTALED do to freak electrical fire?(that started at a wireing harness ford neglected to tell me should have been recalled as they did with the 95se) I miss this car.
NEW PROFFESSION AS A TROLL.
new car. 2000 dodge dakota 4.7l v8. custombuilt intake, custom exhaust, kennebell pcm, and electric fan conversion, 180 stat, 3.55 pegleg, my old stereo system, 17x7 billets and 255-50 nitto 450 tires. next drop and traction adders. g-tech 14.5
in search of 95 se fivespeed to hang contourparts on.
Posts: 148 |
I was thinking about putting straight pipes where the pre-cats are, and leaving the main cat alone. Would that make a positive or negative effect on the car?
98 SVT Black w/ Midnight Blue Stock Rims Sparco Pedals Removed Resonator TH Fix Superwhite Bulbs B&M Shifter K&N Filter KVR Cross-drilled rotors (front) KVR Pads (front/back) Aeroquip Steel brake lines (front) #4248 of 6535 built 15.574 @ 88.35mph 15.814 @ 86.62mph
Posts: 130 |
What i have seena lot of people do, including my brother on his offroading beast, is take OUT the cat, and add just a straight pipe where it use to be, and then when it comes time to get a stupid E-Check, swap the pipe for the cat  seems to work really good, considering you do loose some power using the cat.
99 Grand Am GT ower LOVE FORDS THO! GO SVT seriously! MAF mod, B&M Shift Kit (no manual trans.) Lexan Intake 7" cone, Next.... Borla Exhuast, ASE Chip Reprogram. Suspension mods next summer  Just WON Ram Air Hood and Spolier! BEST TIME: Norwalk Ohio 15.216@88mph Also painted "Metal Flake Blue" interior SHARP lookin! *NEW* AED Rear Facia, Lotek Pillar guage Pod and guages!
Posts: 216 |
....or instead of putting the cat back on for the emissions test, just take your car back to the muffler shop that removed it in the first place. I'm sure they do emissions testing. They'll make it pass!
-Tim, Former crush: a '95 Contour GL 2.5L, 5-speed. Current love: 2001 Toyota Tundra SR5 King-cab 4x4.
