All
95SE manual 115k, maint up-to-date.
Returning here after several months. Awhile ago was havng intermittant starting issues, local mechanic ended up saying it was the fuel pump (a good trustworthy person). So i replaced it and it ran well for several moths. Then the last month or so the problem seems to have returned. Again its very intermittant - like running well for a week, then it will turn over strong but never start, leave it a bit and its fine again. Now a couple times it started but the idle hunted around for a couple minuteds before settling in - no response to the throttle at all while it was doing it, then settle down and be OK. If it would stat it would run ok - hesitate at certain revs, almost stall coming to a stop....
So anyway - after the last prob, I cleaned out the IAC as in the tip sheet, checked all my connections, gave it some fuel injector cleaner, and changed the air filter. Started since then but we'll see on that.
But - one thing have noticed and just nailed down, is a scraping, metalic noise during the first second or so during statup. Really like metal scraping - finally pipointed it - i think! - to whatever that round UFO thing is in front of the IAC. Sounds pretty scary - seriously like letal scraping for 1-2 seconds. What is that thing and can it make a noise like that? Lost my haynes manual.. BTW - Air cond does't cool anymore either - not sure if the timing ws similar or not. I do need to change the cabin air filter....
any ideas on that noise?
Reading through old posts has helped me fix a stereo issue, a blower switch thing, and the IAC clean - so thanks for all the knowledge beforehand.
