Posts: 31 |
how much nos can my car handle i was thinking about first getting a 50 shot and working up to a 75 or 100 [censored] what do u guys think?
1998 Contour SVT "tuxbaby"
Posts: 7,025 |
I know Y2KSVT is running the venom kit and has seen about 3 bottles on his 20% shot. Seems quite a bit underated because it put down an extra 80 hp on the dyno.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 4,270 |
uhhh, 75 TOPS, run anymore and you'll break somehting... "sh!t, he's got enough nos in there to blow himself up"
~Alex
Ex- SVT Driver627
MUST SELL!!!LOCAL:
Pre-98 MOLDED trunk
Polk db speakers
Corolla parts
LED Underbody Kit
PM
2000 Green CSVT gone on 2/17/06
2001 Toyota Corolla (SHE RUNS!!!)
1989 Mustang LX 5.0
Posts: 9,602 |
Your car can handle more then NOS.
It can handle Venom, ZEX, Nitrous Express, and others as well.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 200 |
I have run a 100 shot for a while now. My car is tuned for it and it works great, plugs are checked all the time and they have no signs of running too hot or anything. I may go to my final 125 shot next spring. I would recomend if going to a large shot like this get the car tuned for it, fuel and timing must be set properly. I am using a wideband o2 to monitor my afr's just incase, I use it to fine tune as well.
98 Contour SE 3.0L 5-speed
SCT PRP, Gutted IMRC's, Fidanza Flywheel, Race Ported 2004 3.0L Oval Port, Zex 125hp shot, 70mm Mustang TB, 42Lb injectors,Walbro 255 pump, Traction Bars, Zeitronix wideband o2, lots of little things, 10,000K HID's!!
Posts: 6,760 |
+1 [search nazi on] Obviously your keyboard can't handle the search function[/search nazy off] Originally posted by DemonSVT: Your car can handle more then NOS.
Ryan
Trollin!
Posts: 638 |
well, first you need to find out the weight of NOS then divide the vehicle's gross cargo weight by the weight of a single kit, this will give you the absolute maximum amount of NOS you can put in the car, however, if you intend to be in the car at the same time, you will need to subtract enough NOS to compensate for your weight. You will also need to compute the volume of NOS and the maximum volume you can use in the car for the placement of NOS, space may or may not be adequate for the maximum computed NOS avaliable by weight, if you have extra room, then good you could even put an ebay chip on it. However if internal vehicle volume is not enough for the maximum computed NOS, you could just bolt it to the roof.
87 Mustang GT 5.0L TURBO
Posts: 6,106 |
Anyone who refers to it as NOS, should NOT be considering NITROUS!!
Mark
2000 Black CSVT
Posts: 9,602 |
Originally posted by Y2KSVT: Anyone who refers to it as NOS, should NOT be considering NITROUS!!
Don't you run NOS Mark???
2000 SVT #674
Posts: 1,605 |
Is Nos the same thing as NAWWWWZZZ, because i can run a 350.8HP shot of NAWWWWZZZ!
#3162 of 6535
98 SVT Silver frost
Viper Responder 791 w/ 2way remote start
Let the modding begin!
