There should be no effect on low end power with gutting precats. This is due to the principal that lower rpm requires less airflow and therefore there is less exhaust. The flow of the manifolds will be more than sufficient for low rpm. If anything you should notice and increase in higher rpm power since they will be more open and can handle the increased exhaust flow that high rpm pushes through. I would expect not to see any improvement until over 5K rpm UNLESS...unless they were starting to plug up. BUt if that were the case you should have gotten a catalyst inefficiency code already.
Only two ways to help the low end grunt. well three ways:
1. Increase timing -- need a chip
2. decrease header pipe diameter -- good for velocity but kills top end power,
3. Install headers -- takes advantage of exhaust pulses and wave dynamics by design.
If you are smart, you can see that numbers 1 and 3 are good, number 2 is bad.
If you are really smart you see that number 1 + 3 will be the best method!
Start with three, then add #1 and get a dyno tune. Plan on $1000 to accomplish these two mods but you will get a huge increase in performance for that $1K if your chip is done on the dyno.
See My Mods
