#101119 07/12/01 05:32 AM
The list of options for more power that I see at this site seems endless. All I'm interested in is some more power, and I don't really care what I use to get it. A 1998.5 SVT is advertised as 195hp at the crank. What kind of money (before I even get into which parts), realistically, would I be looking at to get up to say 195hp at the wheels?
Mike Roberts
98.5 E1 SVT Contour
B&M Short Shifter w/ Momo Race Air Leather shift knob
K&N air filter in modified (hacksawed) airbox
Alpine 60WX4 CD deck w/ 3-way Pioneer Speakers
MTX 280 watt amp powering a single Kenwood 10" subwoofer
#101120 07/12/01 05:36 AM
A 3L swap outright would give you a good 200HP at the wheels.
You'd need every bolt-on made to get a NA 2.5L to make 195-200HP at the wheels. With the last one being a custom dyno tuned chip.
a S/C SVT would give you around 260+ HP at the wheels. Depending on other mods of course
For more detail use the search feature
2000 SVT #674 - Check it out!
#101121 07/12/01 10:52 PM
what's the difference in weight after completing the 3L swap? And after everything's done is it really that much cheaper than an S/C (I won't be doing any work myself; installing the B&M is pretty much the limit of my ability)
Mike Roberts
98.5 E1 SVT Contour
#101122 07/13/01 07:08 AM
SHOShop has the swap listed at $1500 short block and $1750 labor. Since you will not be doing it yourself it probably won't get any cheaper...
A S/C alone is that much. (maybe more now?) Plus install labor. Don't remember time involved but I'd guess $800-1000...
You'd really want a LSD with either mod. Another $1k with 3L swap. $1500+ with S/C (since they'd have to R&R the tranny)
The old saying goes. Speed costs... How fast do you want to go...
#101123 07/13/01 07:09 AM
Weight difference would be neglible. Blocks are almost identical in size plus all aluminum (so size difference wouldn't weigh much)
