#1330320 07/09/05 02:33 PM
hi guys last week i had an accident and now much car pulls to the left alot, i have to keep the wheel 180degrees to the rights to make the make stay straight,what has snapped??
#1330321 07/09/05 02:47 PM
you knocked your car out of alignment, i doubt anything is snapped or else you would know it. take the car in for an alignment and they will be able to tell you right away what you bent or messed up.
mj
Mike C T-Red 99 csvt #490 No longer a dailer driver
#1330322 07/09/05 03:17 PM
oh i see, does it sound like a big bill?
ive just spent 690 pounds thats 1250dollars on fixing the body work and repainting it
aont got much more money left considering im only 18 with no job
#1330323 07/09/05 03:30 PM
Sounds like you took a hefty whack ... check your control arms too. This happened to me before and when we pulled the arm off it the hole was elongated from circular to oval ... while on the car the arm didn't look too bad, and would probably have passed a 'casual' inspection.
I presume you're in the UK (from pounds reference ) I think the last time I got an alignment I got it done for about 25 quid. Depends though on who you know, and where you are, and if they are a decent outfit.
1998.5 T-Red on Midnight Blue SVT Build Number 5320 of 6535
#1330324 07/09/05 03:57 PM
yup im from the uk will post up a couple pics of my mondy when it gets back!
to be honest i have no clue about this part of the car, will the alignment just find what the problem is?
#1330325 07/09/05 08:32 PM
If the alignment doesn't sort it then there is a bigger problem. Try the alignment first, especially if you can get a good price on it.
If after alignment it still becomes un-aligned, then look into other problems.
Check your tyres too, what caused you have bodywork done? Did you lock up, hit a wall (like I did ) or someone hit you. Basically, the higher speed imapct, and the more it's localised towards the wheel area means the greater chance that something like a LCA might be bent. If you hit a curb, for instance, then it's probably just alignment.
Get it done right away though, saves on additional wear for one, and safety aspects too.
#1330326 07/10/05 07:17 AM
another car hit me at aboout 30mph, they actually hit my front wing/bumper aparantly its the wishbone but im gonna have to wait till tuesday to find out the full effects
