Page 3 of 3 1 2 3
CEG road warrior
CEG road warrior
I had all four brakes smoking at the Dragon last year.
As usual, you're just a little bit different...
Your car is a little bit different, (ie, the way it works and gets handled). Must say, coolest Zetec ever though...
I drive it hard to say the least!
I
I
All the time, very hard on brakes. I had a 00 Grand Voyager and in 20,000km of ownership, I replaced the brakes twice. Same with my Eagle, I bought the car @ 233k and now at 292k and replaced them 3x...
Ian ~1998 Ford Contour SVT Duratec 2.5L V6 24 valve~ ~1989 Eagle Premier ES, PRV 3.0L V6~ www.ian-dagenais.freeservers.com
I baby my brakes. When slowing down,I use both downshifting and braking together to bring me to a stop. I would also rather do a brake job than replace my tranny,but I've already done both on my car in the last 2 months,so collectively,I've spent $950 on my tranny and around $700 on brakes.Rear oem rotors and shoes,front oem pads,and in the next 3 weeks will be picking up SVT calipers and KVR pads for $200 and slotted 278mm rotors with cadmium plating for $360 with shipping and taxes.
I only slam on my brakes if I'm about to hit something and die....which isn't very often. I find my 4 wheel disc setup on my Tour is much more effective than the disc/drums on my Mystique,but I still feel like I'm lacking braking power,so the SVT upgrade should make a difference.
'95 CGL ZMTX - DOB: 8/94 - Daily Driver - 271k & counting - Ractive muffler,MSD ignition coil,KEM 8mm wires,Pre98 SE 7 spoke rims,KVR CF brake pads,Post98 sail panels,Sony Xplod HU,Pioneer 3-way 6x9's '89 Mazda B2200 - Under Construction
The SVT upgrade will really only help you on hard and/or fast stops. I find coming down from 75mph of the highway is a lot smoother then with the stock SE brakes. It's a worthy upgrade though... I'm glad I did it.
-Chris 2000 SE Sport V6 5spd (all stock except for EO brakes)
liquidX Offline OP
I shouldn't have to slam on them when I get my new titaniramics from Stazi... next year that is...
Page 3 of 3 1 2 3
